MAGICSEE N6 MAX TV Box RK3399 Android 7.1 4/32GB Dual WiFi Gig Lan USB3.0 4.1
    Originally posted by fenece View Post
    Hi at all.... I've another big problem with this device: Amazon Prime Video install correctly, I login but when I play any video the app crash :-( :-( :-(
    I've try different apk but same problem!!!
    Anyone have resolve this issue?!?
    Thanks a lot
    Hi, Magicseen have reply me yesterday about Amazon Prime Video problem:
    Subject: Re. Amazon Prime Video on Magicsee N6 Max device
    Thanks very much for your support on Magicsee
    Our engineers are working on it now.
    All RK3399 tv box have the same problem,
    we will release a new firmware to slove the problem.
    Anything news we will inform you
    Any question, feel free to contact us.
    Best Regards
    Shenzhen Magicsee Technology Co.,Ltd
    Tel: +86 755 26532142
    ADD: No.242,Xixiang Road,Baoan District, Shenzhen city,China
    website: www.magicsees.com
      noahv Amazon Prime works on MK39 firmware ?
        Doesnt work either MK39 firmware or y8 scv1 firmware..
        Keeps giving error when clicked to video and app closes.
        Probably rk3399 Kernel related issue.
        • mo123
          mo123 commented
          Editing a comment
          I could easily fix it if a company sponsored me a quality RK3399 device and the latest source code.
          But I don't want to fix Magicsee's mess.
        Originally posted by sidglide View Post
        Would you think x99 forward will also work with this device..
        Hi ,
        X99 has DDR3 , N6 has DDR4 , dont think it works , same for X99 only DDR3 Roms shall work ,
        but i am no Dev. , good luck / greetings / gefattern
          The rk3399 seems to show many of same issues,
          Regardless of the device manufacturer.
          Where's the source code that rockchip tested this soc with? Surely it is Not beta, but a release fw.
          - Can Anyone report a type C port working Properly?
          - IS the pin to pin sameness with lesser RK chips have Any benefit?
          - Perhaps Cloudnetgo Fw may run on the n6?
          ​​​​​​... despite ddr3, it is said to be built with ddr4 also.
          Notice the configuration specs :
            Hi ,
            well without trying we won't know because for example N6 Max (DDR4) firmware works for Rikomagic MK39 (DDR3)
              Originally posted by noahv View Post
              It is obviously not TRUE. I even managed to make it work on MK39 firmware via adb command shell.
              (http://www.aftvnews.com/how-to-set-c...-without-root/) This method also works for MK39 firmware
              Yundoo y8 scv1 firmware ; sleep +screensaver working out of the box.
              Yes i needed to fix it of course... they can fix it in the sdk no problem.......!!!!
              The Amazon Prime Video can also be fixed just fine in the sdk....!!!
              They are just to lazy to do it!
                Cloudnetgo CR19...
                Cr 19 firmware .Maybe it's useful for someone.?
                  Hi ,
                  WoW , did not know that ,
                    Hi everybody. On 4pda too look for an opportunity how to hide the top system bar. Perhaps if you replace Systemui.apk from the other firmware rockchip 3399... For example, use UI from yoodoo Y8. In the topic Y8 there are reports that the 7 beta firmware solved this problem. There is a hide button. I don't know if it's true or not. After reviewing this topic I have not found a solution to the issue of the first pages.
                      Hi ,
                      so you look for a solution to hide the top bar , only , or Notifications too ??? , yes ,
                      uninstalling "Systemui.apk" makes this , but then i think "Notifications" pull down
                      will not work anymore , why not try a different Launcher , on my X99 , no top bar ,
                      but Notification , i use the ApexLauncherClassic , no need to uninstall the "Sysui" ,
                      of course some Roms hve the "hide" Function , but most not , because they have
                      all still many Bugs ,
                      hope it helps / greetings / gefattern
                        Hi guys,have nice Sunday
                        Got this message from GearBest Co.(according to my Ticket)
                        Dear Can,
                        Thank you for contacting GearBest.
                        We apologize for the delay in answering you.
                        We again apologize for the issue with your item and will do our best to help you.
                        In order for us to assist you further and offer a solution could you please try the following:
                        1) Please try to connect to the USB flash drive and check if it can be read?
                        2) Try connecting a wired mouse to see if it is usable?
                        Kindly let us know your feedback to each of the above points.
                        Once we have received your information we will look into this issue in more detail.
                        Please kindly review our warranty here : http://www.gearbest.com/about/warranty-and-return.html
                        Again we sincerely apologize for this and any inconvenience caused.
                        Thank you for your kind understanding and assistance.
                        We will do our best to help you.
                        Are they kidding me,its totally weird
                        sure,all my USB2.0(2 ports)and USB3.0(1 port) read USB Flash Drives!
                        BUT as you know Type-C Port still does not work
                        And I'v tested with "Wired Mouse" and all ports worked too(except Type-C Port)
                        I'v requested full refund or some partly refund(as same as my X99 deal and got it $ 42)
                        Bye++
                          Hi ,
                          come on,all are with many BUGs
                          Dont try this and wait what MagicSEE do it
                            https://cloudnetgo.m.manufacturer.gl...gb-android.htm
                            Hi
                            Still N6 MAX;"Type-C Port" does not work! even with latest f..... F/W too
                              Hi
