It can be a bit noisy on startup, but that goes away after a minute or so.
NEOTV CROM 1.5 MK802IV Old Wifi,MK809III,UG007B,QC802,Cloudnet Go CR9
Originally posted by TVDroid View Post
And you have a link to the FAN ? Its not too loud ?
It can be a bit noisy on startup, but that goes away after a minute or so.Freakbox V1 F/W 1.0.6
Asus Zenfone 2 ZE551ML Stock (rooted)
Samsung Galaxy Tab 3 7.0 Nolekat 2.2 custom ROM
Asus TF300T Cyanogenmod 11 Snapshot M12
Archos 35 Home Connect Stock 2.3.4
Originally posted by Rockko View PostNot to be annoying, but if the ROM was working well, the device wouldn't crash. You don't mention the device you have, but I have been running NeoTV 1.5 on an MK809iii since the ROM was released. Initially I also had occasional crashes, which I could trigger by running a picture slideshow for some time.
The MK809iii initially didn't have a real heatsink, just a layer of heat-conducting foil. It's the same stuff that is used on the bottom side of the MK802IV. I decided to add a 25x25x20 mm heat sink. That improved things, but it still suffered from a lack of airflow. So I bought a small fan and added that. Now the device is mostly stable and only crashes occasionally when using Chrome Beta.
I really believe that most Android sticks with the RK3188 are insufficiently cooled. Devices with the AP6210 WiFi do have a small heatsink, but from what I read it's still barely sufficient. Especially when you're using overclocked and/or 1080P kernels.
The recently launched RK3188T, which causes so much discussion, may have a big advantage over the RK3188: because of it's lower clock speed, it will become less hot. That makes it suitable for small devices with passive cooling, like our Android sticks.
Originally posted by ilovemymac View PostHow do you know if you have an MK802 IV with old wifi or new wifi?Freakbox V1 F/W 1.0.6
Originally posted by chtheo View PostI would like to buy a webcamera for 802IV. Which models are working??
If there is a list I would apreciate it.
There are currently 2344 users online. 0 members and 2344 guests.
