A95X Max TV Box - Amlogic S905X2 A8.1 4/64 ROM Dual WiFi Gig Lan BT4.2 + Support 2.5inch SSD / HDD
    Specification as Found
    Type: TV Box
    GPU: ARM Dvalin MP2
    System: Android 8.1
    CPU: Amlogic S905X2
    Core: 2.0GHz,Cortex A53,Quad Core
    RAM: 4G
    RAM Type: DDR3L
    Max. Extended Capacity: TF card up to 128GB (not included)
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: AVI,DAT,H.264,H.265,ISO,MJPEG,MKV,MOV,MP4,MPEG,RM, WMV
    Audio format: AAC,FLAC,MP3,OGG,RM,WMA
    Photo Format: BMP,GIF,HD JPEG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: Yes
    Bluetooth: Bluetooth 4.2
    Power Supply: Charge Adapter
    Interface: AV,DC Power Port,HDMI,LAN,SPDIF,TF card,USB3.0
    Language: Multi-language
    DVD Support: No
    HDMI Version: 2.1
    Other Functions: 3D Games,3D Video,DLNA,ISO Files,Miracast,NTSC,PAL
    External Subtitle Supported: Yes
    HDMI Function: CEC,HDCP,HEC
    RJ45 Port Speed: 1000Mbps
    System Bit: 64Bit
    Power Type: External Power Adapter Mode
    Remote Controller Battery: 2 x AAA Battery ( not included )
    Product weight: 0.2600 kg
    Package weight: 0.6300 kg
    Product size (L x W x H): 13.00 x 13.00 x 4.50 cm / 5.12 x 5.12 x 1.77 inches
    Package size (L x W x H): 20.60 x 14.60 x 6.40 cm / 8.11 x 5.75 x 2.52 inches
    Package Contents: 1 x TV Box, 1 x Remote Control, 1 x HDMI Cable, 1 x Power Adapter, 1 x English Manual
    Gearbest
    Coupon:GBA95XMAX will save a few Bucks
    Gearbest < Click
    $68.69 after coupon: FEVMJNDO
    Geekbuying < click
    What kind of remote control does the box have? (Photo?)
    Who is the manufacturer and how much is the firmware development supported?
    I choose from three Android TV boxes:
    1. A95X Max TV Box - Amlogic S905X2 A8.1 4/64 ROM Dual WiFi Gig Lan BT4.2 + Support 2.5inch SSD / HDD
    2. Beelink GT1 MINI TV Box with Voice Remote Amlogic S905X2 Android 8.1
    3. MXQ G12 Android 8.1 TV Box - Amlogic S905X2 4GB LPDDR4/32GB EMMC Dual WiFi BT4.0
    Most important considerations:
    4GB/64GB or 4GB/32GB
    1000Mbps
    WiFi 5GHz (2T2R)
    High reading and writing speed (internal https://i.imgur.com/oTRXEhf.png and external Micro SD Card Reader)
      Trebor,
      Are you going to review this TV Box? I want to see your review before buying this TV Box.
        it looks great... is it rooted?
          i just ordered this box, i wonder is there any dts/dolby sound problem with amp receiver, there was problem with s905
            HD Audio won't work in Kodi.
            But with the built-in app or vlc you should be able to play most HD Audio formats and Dolby Digital.
              İ dont care hd audio but there was stutter audio at dolby/dts movies with my s905 tv box, i hope that solved with s905x2
                Until today I had fun with a few Mecool M8S PRO L. This box made me curious and I also just ordered.
                16.01.2019
                Today after one day of fun, I regret that I bought ... At first, the USB flash sticks are does not work !!!
                USB keyboard and mouse works. It is, clearly, still a very young device...
                Next problem when HDMI connecting to the old Philips TV 37PFL8404H (HDMI 1.3):
                paiktaras69 DRM Info App shows L3
                  seems remarkable !!!!
                  someone knows is widevine L1 or L3 ?
                      AS found: A95X MAX S905X2 ANDROID 8.1 TV BOX FIRMWARE UPDATE 20190109
                      http://geekbuying.mediafire.com/file/04ji1y5c4596bmk/A95X_MAX_20190109.rar/file
                      blog.geekbuying
                            #Super SU - Super Issue
                            Super SU bricked my box. after updating binaries and rebooting, I've got now the A95X logo and nothing else
                            So, I tried
                            • reset by AV port
                            • wipe data / factory reset from stock recovery
                            then, I dl A95X Max 20190109 firmware from geekbuying ( #11 thx trebor )
                            • Burn Card Maker (with or without reset press, don't boot on SD Card)
                            • USB Burning Tool (2.0.8, 2.1.2, 2.1.6) I can connect on W10 pro 64 but when I load the img file i got "key file not exist" message.
                            maybe I need the license folder with A95X Max mac_ether.ini, in USB Burning Tool or a way to write the MAC adress from sticker...
                            what i'm sure is I need your help to fix that.
                            thx
                            • trebor
                              trebor commented
                              Editing a comment
                              Not sure why you would need SU as it has root switch in setting
                            Hi,kanzi
                            Bad news!
                            hope you will fix it in soon
                            Therefore I bought this Device today fm Geekbuying(RAM4GB+ROM64GB)
                            Meanwhile I already use N6 MAX(RK3399 with very bad FW and a lot of important issues!)
                            I always worry about those ROMs!!
                            Let me ask you why you flashed?? or whats happened with stock ROM??
