A95X MAX S905X2 4GB DDR4 64GB eMMC 4K Android 8.1
Support SATA 2.5 inch SSD/HDD Dual Band WiFi Bluetooth Gigabit LAN USB3.0*4 Video Recording with LED Display
Highlights as Found:
Android 8.1
A95X MAX is one of the first TV Boxes to run on Android 8.1 (an update to Oreo). This software update allows for a great user experience with steady performance.
Amlogic S905X2
A95X MAX runs Android Oreo on Amlogic S905X2, an upgrade of its S905X predecessor with the same quad-core Cortex A53 cores paired with a ARM Dvalin MP2 GPU but adding VP9 hardware decoding, which is the absolute mainstream decoding formats around the global.
DDR4 4GB RAM + eMMC 64GB
It uses a DDR4 4GB RAM and an eMMC 64GB for better performance, security and reliability.
2.4G/5G Dual Band WiFi
With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data.
True 4K Media Player
While your average media box might only accept 1080P video playback, this gadget plays just about any 4K source.
Must say it is a impressive looking device and that remote again a real looker if i say so myself
as you will see this is loaded with ports and has the ability to take upto a 2TB HDD..
Be interesting to see how this was all works out tru sata bridge or just tagged onto USB, whatever it should be ok for the intended purpose we can hope
Let's have a look see:
The Box:
What's in the Box: Good looking remote
The look around: Lots of USB's and other normal goodies
Underneath:
Pop Top: Love the Faux Copper look
May have noticed small switch above network/HDMI port: HDD location
