A95X Max TV Box - Amlogic S905X2 A8.1 4/64 ROM Dual WiFi Gig Lan BT4.2 + Support 2.5inch SSD / HDD
Hey-o!
I've just got one of these boxes and I've only been looking at for a few hours. I've discovered
1. the mouse must be in the USB2 port if you want to use recovery,
2. the left mouse button is equivalent to a simple tap on an android phone,
3. the right button works as a tap on the back button,
4. there is no power switch (which seems incredible: do you leave it on all the time or pull the power plug??)
5. the launcher is brutally ugly.
I don't know how to simulate a "recents" click or "menu" or "home". Any pointers would be appreciated.
I was hoping to get control of recovery with TWRP, as explained in this tutorial, which has a link to a s905x2 version of TWRP, but the test phase didn't work. I couldn't get the A95X MAX to boot into TWRP by powering on with the reset button pressed and a SD-card with the TWRP image. It didn't work: it went straight to the stock recovery without recognizing the TWRP image on the SD. I don't want to flash this recovery until I know that it works.
There are a few ROMs in circulation for s905x2 boxes (atvXperience, Poison?), but I don't know if they will work on the A95X MAX. Has anyone had any luck?
with an external power supply, the best way is to use a plug-in switch. If there was a power switch in the box, your power supply would be always on, even if your box is shut down
For this Box even mostly,use "AirMouse"
This is the best way in order to use for all full functions!
Buy cheap&pricey etc., Airmouse then use it without any issue
A95X MAX;own RC worst ever! also you cant command "upper lines" with most of Apk.s for example "MXPlayer" WTF this RC
the worst/bad RC ever
I always use AirMouse(bought about $ 10) and using with all my Boxes
FYI;there is no any Advanced "Picture Settings" in fact those settings remain the settings section but it doesnt WORK!
Manufacturer(I always contacted with Geekbuying AfterSale Dept.)never fix it this! So dont wait any Bug-fix for the
"Picture Settings"!
In this respect Geekbuying paid me $ 20(partial-refund)WTF
"Picture Quality" not bad or a little bit more performance then AML912 but way far a way from RK3399!!!
Do not wait RK3399 Picture Quality fm the AML9xx !! even this Box
I'll sale this box within couple of days(given my sale list to local marketing company)
Important;PSU is 2.5Amper its not powered well! such as I use it
1x1Tb ext.HDD(Toshiba Canvio=this HDD consume more power!! WD/Seagate more less!)
2xUSB3.0 Flash memory
when I using this ext.HDD for fastforward/rewind action then its stop it or freezing!! or turn to Main menu with 2.5Amper org.PSU
than I'v changed and connected my 3Amper PSU than its OK seems no issue
So if you use this box in a long term condition Buy at least 3Amper PSU even 4Amper!
I'v two spare PSU 3 and 4amper
For me this Box is a not right device for my expectations
Only one Pros.;it has internal HDD bay
WTF
sometimes I got warned
...your message seems potantial SPAM....
and need "Approval"
are you kidding???
Mod,you should be BANNED me pls
I never write again in this forum
Cause of all my msgs SPAM!!
You can set Sleep now, Shutdown and Restart in Settings, Advanced settings, and Powerkey definitions.
Check out the Youtube directions for this box.
Hi.
What do other users do about power? Do you leave the A95X on all the time? Have you discovered how to use the "powerkey"? Do you turn it off at the plug?
And I see four round icons at the top of the launcher: the first I don't recognize; the second has SD, but doesn't seem to do anything; the third is a settings button; and the fourth has a cloud, which when pressed asks for a city, but I don't understand what it is. Beside the settings icon, what exactly do the other three do? Any ideas?
Oops, just got a system update 20190304 and it removed the cloud icon!
There are many things that are unexplained: these launcher icons, various things in Settings. I did notice a "Root Switch" in Settings. If you have sensitive apps that refuse to work, eg for your bank, it could be because the Root Switch is on. Try turning it off.
● Just noticed that if you push the mouse to the top of the screen you'll get the notification bar. This is like going to a country where you can't speak the language or read the signs, so even the simplest things you have to discover!
As said "bergamesk" it is best to use "AirMouse". As I said go to "Settings, Advanced Settings, and Powerkey Definitions" and there you have the option "Sleep now, Shutdown and Restart".
I have marked the "Shutdown" option and when I press the red button on the remote from the box it goes out all over and even the display.
After that, I turn it on again with the red button.
And I'm still learning with that box.
As for those 4 icons, I do not even know what the first icon is and SD is probably an SD card icon (if you put it in the device). The cloud icon probably served as a "google cloud" or similar and disappeared with an upgrade.
"Root Switch" is the same as my cell phone. When you have it, you can change anything on your cell phone, but only what does 100% make for your cell phone.
In the future there will probably be other modes for this Box ( like "Roms"). And now we can change the launcher.
OK we are learning and tracking youtube and forums for future upgrade of this Box.
Such as:
There is nothing left about him yet, which does not mean it will not be in xda forum.
Type in the search engine on xda forum, "TV Box" and you will see that there are already many devices that have support.
Nice greeting.
Originally posted by marijan View PostAs said "bergamesk" it is best to use "AirMouse". As I said go to "Settings, Advanced Settings, and Powerkey Definitions" and there you have the option "Sleep now, Shutdown and Restart". I have marked the "Shutdown" option and when I press the red button on the remote from the box it goes out all over and even the display.
Originally posted by marijan View Post"Root Switch" is the same as my cell phone. When you have it, you can change anything on your cell phone, but only what does 100% make for your cell phone.
Originally posted by marijan View PostAnd now we can change the launcher.
Originally posted by marijan View PostOK we are learning and tracking youtube and forums for future upgrade of this Box.
Such as:
Nice greeting.
There are currently 1866 users online. 3 members and 1863 guests.
