A95X Max TV Box - Amlogic S905X2 A8.1 4/64 ROM Dual WiFi Gig Lan BT4.2 + Support 2.5inch SSD / HDD
    I'm using ugos launcher, it is simple, and very nice for me.
    Sent from my Mi MIX 2S using Tapatalk
      what is the latest firmware number
        A95X_MAX_B-8.1.0-201903041010
          I downloaded a little app called Quick Reboot which gives the option to
          1. shut down
          2. restart
          3. fast restart
          4. reboot to recovery
          5. reboot to bootloader
          6. reboot to safe mode
          Number #1 will be the most used option and it means mouse users don't have to pull the power plug.
            I responded to this earlier but the forum software got confused and has marked it unapproved. I'll delete the text and repeat here.
            Why do u need connect tv box to pc?
            mine is not connected to pc, the hdd is connected to box by usb port and not extra powered, so if u pull the power cable from the box of course theres no led light, but not practical as i said before
            I misunderstood your post and thought the light was an indicator on the A95X MAX display. If you were connected to a PC via USB you'd still get power via USB.
              Is it possible to cast in a95 max from phone, Netflix?
                mine is february and ota update fails
                  yes u misunderstood i have talked bout usb hdd led light connected to box....
                  and if u want to connect a box to a pc it requires a usb type style like this in the picture (the blue one)
                    [deleted]
                      This box is not an A95X MAX. The layout of ports is nothing like the A95X MAX. The USB3 connection is not the type on the A95X: it's not Type-A. I don't know why you posted this image: it has nothing to do with our box. Are you on the right forum?
                        Looks like a Himedia Q10 Pro box
                          İ know thats not a95x max, thats himedia q10 pro, i got both of these boxes.....
                          People talk here to connect a95x max to a pc, i want to tell there must be a usb type on a95x max too as himedia.... But a95x max has no.... So its not possible to connect a95x max to a pc i think
                            It is this launcher ?
                              Yes...
