A95X Max TV Box - Amlogic S905X2 A8.1 4/64 ROM Dual WiFi Gig Lan BT4.2 + Support 2.5inch SSD / HDD
Originally posted by marijan View PostI do not know English very well, so I'm sorry you did not take pictures where you exactly solder the red wire and where it was black.
Is this the place exactly where it was supposed to be a fan connector?
Please help.
Thank you.
And my A95X MAX using time is over
Its under "Sale" link!
My new Box will be(most probably) New chip S922X
At present very few supplier/manufacturer produce this Box and according to initial/first looking reviews this Box seems better than
all previous AML Boxes even on some points a little better then RK3399 !!
ODROID N2,Beelink GT-1 King and UGOOS AM6 first Boxes with S922X(in fact not first!)
I prefer Ugoos
My reason of sale of the A95X MAX
1-No any "Advanced Picture Settings"! actually it has but Not working! and for this lack of setting I got $ 20 partial-refund from GeekBuying Co.
2-"Picture Quality" Not satisfied me even versus RK3399!!
Originally posted by JKow View PostUntil today I had fun with a few Mecool M8S PRO L. This box made me curious and I also just ordered.
16.01.2019
Today after one day of fun, I regret that I bought ... At first, the USB flash sticks are does not work !!!
USB keyboard and mouse works. It is, clearly, still a very young device...
Next problem when HDMI connecting to the old Philips TV 37PFL8404H (HDMI 1.3):
paiktaras69 DRM Info App shows L3
37PF9731D/10
Beleef de ultieme kijkervaring met deze Philips Cineos Flat TV met Pixel Plus 3 HD, Ambilight Surround en Clear LCD-technologie. Met de Digital Media Reader met PC Link hebt u toegang tot alle multimediacontent.
I prefer Ugoos
As for picture quality set up from box is limited but I can return at tv.
In term of price to quality its a good deal and had good option available additional hdd and optical out.
To archive high picture output try fiber optic HDMI they are really good and cheap compared to branded hemi cable.
Originally posted by bergamesk View PostHi xbalance
...To archive high picture output try fiber optic HDMI they are really good and cheap compared to branded hemi cable....
any recomm.Brand?? price doesnt matter!
or any cheap or high-end
xbalance
I've seen your picture with a DC power connector that has a 3 pin facing bottom of board but I'm not an expert and I'm still not sure where the red wire is going and where black. You showed up with arrows on two connectors, to which red wire came.
Sorry but I do not know.
Leoben
But the A95X MAX S905X2 4GB - 64GB motherboard does not have a fan connector slot, while allegedly in 32GB has.
I bought this fan:
DC 5V Computer Cooler Mini Cooling Fan 40MM 40x40x10mm Small Exhaust Fan for 3D Printer 4010, 2 Pin
Thanks for your answers.
Leoben
I bought this fan:
well im also not expert, can you do soldering ? if yes good, if no please practice before apply.
To identify which is which... cut the wire connector then turn on your box and connect wire to the pin. if wrong wire color connect will not damage just fan wont move.
im also using this way to check before solder. remember fan have push pull wind function.
There are currently 3002 users online. 1 members and 3001 guests.
