A95X Max TV Box - Amlogic S905X2 A8.1 4/64 ROM Dual WiFi Gig Lan BT4.2 + Support 2.5inch SSD / HDD
i use the box active for few months....its good when tv turned on/off box does the same, no problem with dts/dolby digital, i connected logitech z906,
months ago the light of 2.5 samsung hdd was still on even if the box is turned off..now when the box is off, the light of hdd is off too, thats fine
Hi people. I need some help.
I bought an A95X Max tv box and plugged it into my Sony bravia W955a tv.But the TV remote control is controlling the TV box and I can't reset it.
I tried to clip the reset button on the TV box to return to factory default (reset everything normally). But the control of the TV continues to control the TV box.
I think the IR on TV control is the same as the TV box.
I do not know what else to do. I want the TV box remote control to be the one to control it. Any idea?
Originally posted by 5p0ng3b0b View Post
Might need to enable status bar at bottom of screen in settings then click on the double rectangle icon.
If you use a keyboard then press alt-tab.
Is it under a different name?
Originally posted by cjeman View PostTo launch the status & notification bars you need to hover the cursor near the bottom of the screen and left click. Both bars will appear. I would like to see this persistent by some means. There is no command in settings to make this so.
Originally posted by mlobo View Post
I tried that! hovering the mouse near the bottom of the screen doesn't show anything!!Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
There are currently 1661 users online. 1 members and 1660 guests.
