A95X Max TV Box - Amlogic S905X2 A8.1 4/64 ROM Dual WiFi Gig Lan BT4.2 + Support 2.5inch SSD / HDD
Originally posted by doktorspon View PostPerhaps check out ... It'll show you how to flash back to stock
the issue is mine is A95X F1 - S905W (not Max S905X2), I'm not sure if the firmware he references 4 download is the 1 I can install on mine.
Originally posted by nskmda View Postthe issue is mine is A95X F1 - S905W (not Max S905X2), I'm not sure if the firmware he references 4 download is the 1 I can install on mine.
Chinagadetsreviews.com should have a stock firmware image for your device I believe, and the custom AndroidTV firmware from atvXperience.com version v2FF will directly install if you use Amlogic USB Burning Tool.Last edited by RiCkLaR_atvX; 30 June 2019, 08:34.
Originally posted by RiCkLaR_atvX View PostYou need to be asking for support in the correct forum topic, this is A95X_MAX topic.
i felt like this topic was the closest 1 to the issue i have on hands...
I used this launcher: https://play.google.com/store/apps/d...cher.pro&hl=it
I must say it's not bad!
There is a custom rom for this device: Sidiwen A95X MAX TVCPU Amlogic S905X2?
thank you in advanceLast edited by Alex-77; 24 June 2019, 22:59.
Originally posted by Andnet10 View PostHello
thank you very much for your explanation and I have a question on the same subject of registration but since the application iptv Extreme a programee recording and I would like to make this record worm hdd and not on 64GB (ROM)
THANK YOU
An example with Go Recorder:
1. Click the box in the top left corner
2. In the item "storage" click on Workspace
3. Go Recorder shows a folder list with "/storage/emulated/0" at the top
4. Click the first item ".." and again ".." to have "/storage" at the top
5. Choose your storage. (It will be a hyphenated pair of hex numbers, eg 4DA6-FC09)
6. Press OK and you've changed the desctination
Hopefully you can translate that for your situation.
Originally posted by Rocco86 View PostHi
Pls.help me how the fix bug A95X MAX android box GENESIS USB DRIVE CORUPTED no usb drive in it!
When factory reset the box then it is not there but if the usb connectors are there then again Genesis drive usb corrupted subtitle!! More usb I tried!
You have a USB drive that the A95X MAX doesn't recognize?
If yes, have you tried the drive with a PC? If the PC has difficulties, there is probably a problem with the drive.
If the PC has no problems, then try other USB drives?that work with the PC?in the A95X MAX to see if they work. If not, there's trouble!
Hi!
USB drive is reddy the android box also recognizes it! My problemwhen factory reset the box then it is not there but if the usb connectors are there then again Genesis drive usb corrupted subtitle!! More usb I tried!
My problem:https://imgur.com/yTZqqjE
Sorry my low english google translate!
If I understand you, you want to record something in a different location from the default. I don't know the app you mention, but you have to look in its settings to change the destination.
I understand that you have a USB drive (Genesys) that appears corrupt to the A95X MAX. Can a PC read the USB drive? Yes or no?
Can the A95X MAX read other USB drives? Yes or no?
(Subtitles are translations that appear on the screen when you watch a foreign language film.)
I don't understand what you wrote. A factory reset can't kill its device drivers.
Originally posted by Rocco86 View PostOriginally posted by doktorspon View PostCan a PC read the USB drive? Yes or no?
If your PC has no trouble with your Genesys drive, try this:
1. copy any important files to the PC,
2. reformat the Genesys drive using exFAT
3. test with A95X MAX (corrupt?)
4. if no problems, replace your original files on the drive....Last edited by doktorspon; 07 July 2019, 01:38.
There are currently 2966 users online. 1 members and 2965 guests.
