A95X Max TV Box - Amlogic S905X2 A8.1 4/64 ROM Dual WiFi Gig Lan BT4.2 + Support 2.5inch SSD / HDD
    Armoni
    -I'v replied your quiz couple of days ago!
    -BTW,I'v already tried to connect this Box to my Desktop(Win7) but failed!
    Some of Boxes that you cant connect it to the PC
    BOX-PC connection aciton;
    >USB3.0 to USB3.0(also tried with 2.0)connection+Power Cord+HDMI(to Monitor) FAILED!!
      Hello,
      I bought my A95X Max at ****. I?m pretty sure that the issue is a missing driver so I contacted the seller. He doesn?t know. My old media player (Bluetimes 3548M3) connects to my laptop through a mini usb port (PC host) which driver was already at Win 7. Apparently this (host) feature is related to both hardware and firmware and is not supported in the A95X Max. Yesterday I added five more albums to my collection. I removed the SSD, connected it to my sata3 adapter and to the laptop. There has to be a better way. Anyway, I?ll keep trying to get the driver. I?ll let you know. Have a nice weekend.
        Originally posted by Armoni View Post
        Hello,
        try wifi transfer
          try wifi transfer[/QUOTE]
          Thanks for the reply. That would be an excellent solution. Unfortunately, I have tried it without success. I installed WiFi File Transfer for android but can?t find an option to access the internal SSD since for the A95X Max it is actually an external (usb) device so it?s not presented at the files list. Actually, this ? internal? SSD is connected through a Sata to Usb bridge. Also tried Droid transfer usb connection mode, only to get to the basic problem again. Windows only recognize the A95X Box as an ?unknown device? and has no driver for it. I truly appreciate yor recommendation! Thanks. I?ll try a few more options such as Bluetooth later. Thanks again.
            Out of curiosity have you looked at this video? ("Turn A95X MAX on A95X NAS") The name indicates that it's not about what you want to do, but it might give you some ideas.
              Solved! This app works perfectly giving me complete access to the SSD. I just transferred a new album! so I?ll get the Pro version. Thank you very much!
                Hi guys what is the latest firmware? My shows 201903011658
                thanks
                  thanks
                  Hi
                  when I'v hv checking,seems that>>>>Settings>About>Wireless Update;
                  current version; A95X_MAX_B-8.1.0-201903041010
                  Your FW old and not latest!
                  Check with "Wireless" Update
                  last update dates;March 1st. and March 4th.
                    Originally posted by bergamesk View Post
                    Hi
                    I have checked with Wireless Update setting for updates but it says that there are not updates and that 201903011658 is the latest ...
                      very strange because of mine and yours dates different
                      my previous FW date March1 and now I'v the last FW date is March 4th(the latest one)
                      and also number of FW date is different to,but my previous number is 1658(same as yours) and now mine is 1010
                      Note;where are you?? such in Europe?? might be Australia/USA or UK models may differ!!
                        hi , yes im in uk ,what about you? i checked again now and still no luck ...is there a img of the latest firmware somewhere that i may be able to flash manually?
                        thanx
                          Meguinness
                          Hi,I'm in Turkey(Europe version)
                          -might be UK version different(but I'm not sure that)!
                          -Dont touch your FW!! do not flash manual if you havent enough experience
                          -wait for the next/coming up FW! probably they will release a new FW(if necessary)
                          When FW is coming then you will be notified(on screen advice)
                          -Seems that for the FW upgrade>>> "Ethernet" connection work! I did it by WiFi
                          but some of another A95X user said that by Ethernet connection did it!
                          Have you any issue/issues that it bother you???
                          Such as mine is OK
                            Yes is bothering me that on most apps the top line cannot be selected by using the remote but only using a mouse.
                            do you have same problems? Thanks
                              bergamesk selam hemşerim
                                1-yep,"top line" its not working when you use IR Remote! so you need to command up line with AirMouse or mouse action by your IR Remote
                                its weird but in fact its not bothering me because of I use mostly AirMouse
                                I'v never seen this kind of issue with all my previous Boxes! hope they will fix it
                                2-I strongly recommend you,use AirMouse(but Box mouse remote action just sucks)
                                >I'v bought WeChip W1 Airmouse;pretty good but some of functions missing/not working etc.,
                                such as ON&OFF functions not working! but its not necessary for me and not bother at all
                                but my previous Airmouse do "OFF" but do not "ON"
                                So Airmouse way way better then IRRemote
                                By the way a new Boxes on the way
                                one is a new AML chipset of>> S922X
                                well according to some of tech.reviews this chip kinda fast then RK3399!! its good
                                but I'm not sure about that "Picture Quality"!!
                                In April; Beelink and might be some of other suppliers release this S992X Boxes!
                                Therefore another "new" RK3399 Box is coming too!
                                I really wanna to have RK3399 but their FWs just sucks
                                I'v been used three RK3399 Boxes;H96,X99,N6 all of them disappointment!
                                A95X MAX my last Box but I'll sale it very soon
                                Have a nice week-end
