atvX v3A for A95XMAX PCB v81.zip
A95X Max TV Box - Amlogic S905X2 A8.1 4/64 ROM Dual WiFi Gig Lan BT4.2 + Support 2.5inch SSD / HDD
Originally posted by Leoben View Post
atvX v3A for A95XMAX PCB v10.rar
https://download.atvxperience.com/?d...2%2FA95X%20MAX
However, the ROM is extremely limiting. One doesn't know what AndroidTV is until one is crammed into the restrictions it provides. Even the version of Play Store was limited, you might say "crippled" or even "brain dead".
I found even data entry extremely peculiar. Sometimes I could use the keyboard, but sometimes the enter key didn't work. Sometimes the telecommand worked but other times no. The mouse worked in some circumstances and not others. The provided launcher is just as bad as the stock launcher for the A95X MAX.
Installing the ROM it seems did a factory reset, so anything useful I had on internal storage was gone. In fact, I totally lost control of internal story with an access denied.
Fortunately I had a copy of the stock firmware 20190109 and restored it using the same method for installing the aTVxperience ROM.
The USB cable does work for flashing the device. You just need to know how to use the AMLogic flashing tool, then plug the cable in at the right time. (If you've looked at the aTVxperience instruction vid for the A95X MAX, it explains the process well.)
The big problem with the A95X MAX as explained by N'ayam Amersh'e who was a creator of the aTVxperience ROM is that the bootloader is encrypted, making changes of the firmware system difficult. I can't even seem to be able to load Magisk which needs to rewrite the bootloader, but can't.
Ideally, I'd like to be able to run LineageOS on this box, which is what the operating system should be like, free of the restrictions manufacturer love.Last edited by doktorspon; 13 June 2019, 14:18.
Originally posted by doktorspon View PostI gave this a shot and it loaded as described without difficulty.
I found even data entry extremely perculiar. Sometimes I could use the keyboard, but sometimes the enter key didn't work. Sometimes the telecommand worked but other times no. The mouse worked in some circumstances and not others. The provided launcher is just as bad as the stock launcher for the A95X MAX.
Verstuurd vanaf mijn LYA-L29 met Tapatalk
Originally posted by cjeman View Postdoktorspon. I too would like to see LinageOS on this box. I am running LOS 15 on my Shield Tablet K1 and gave it new life after vVidia stopped providing updates. Where did you get the stock ROM from? The one Geekbuying points to is corrupt.
The link for the ROM is shown at the top:
https://drive.google.com/uc?id=1QfQU...xport=download
Size is 656mb and Google says it's too big to be scanned, but the .rar contains just two files, the ROM image and a license file. You'll need to use the Amlogic Burning ROM program, the latest version here (called "Amlogic Tools):
(If you haven't used the Burning Tool, watch the aTVxperience video from 4:04:
Assuming you've run the Tool setup (see from 2:50), this will tell you
1) about the license folder in which you'll need to place the license file for the stock firmware.
2) how to set up the Tool, &
3) how to flash the firmware
)Last edited by doktorspon; 14 June 2019, 02:03.
Originally posted by doktorspon View PostHowever, the ROM is extremely limiting. One doesn't know what AndroidTV is until one is crammed into the restrictions it provides. Even the version of Play Store was limited, you might say "crippled" or even "brain dead".
Good job on the ROM. If we can get casting to work, that would be my only big request.
Doctorspon..Thanks for the link. I just got a new NUC and I did not install 7 Zip. Both .rar work and I am back to stock. V3B of ATVxExperience is suppose to have NTFS support. I'll dabble with it then for my NAS testing.
ZilogZ80: I have 2 nVidia Shields and find them to be great machines but with a limited Playstore, I wind up sideloading a bunch of apps. Leanback Launcher does not see them so I have to use HALauncher. A lot of compromises with ATV. However, once up and running, apps like Kodi, run extremely well. I would like to see a switch in Settings that would allow ATV or full Android. A dual boot kind of thing. A Virtual Machine with 2 android operating systems. Current hardware could probably not support this. I have a PIPO X7 that boots into WIN10 or Android 4.4. No longer supported and used an Atom chip.Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
Originally posted by cjeman View Post....I wind up sideloading a bunch of apps. Leanback Launcher does not see them so I have to use HALauncher. A lot of compromises with ATV.
RiCkLaR_atvX: I am looking at this box as a an inexpensive NAS. Launcher is really a non-issue, as such. I was just commenting on my experiences with nVidia's Shield. I did install v3a of atvX and it is an improvement over the stock ROM. I use MacroDroid to re-launch HAL on my Shield's whenever Leanback kicks in. Not pretty but works.Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
Originally posted by cjeman View PostRiCkLaR_atvX: I am looking at this box as a an inexpensive NAS. Launcher is really a non-issue, as such. I was just commenting on my experiences with nVidia's Shield. I did install v3a of atvX and it is an improvement over the stock ROM. I use MacroDroid to re-launch HAL on my Shield's whenever Leanback kicks in. Not pretty but works.
doktorspon. I do have SambaDroid up and running. My difficulty is that the SSD is defined as NTSF and shows 0 bytes for files over 4GB when copied from another source. Adding an existing NTFS drive with 4GB or more videos shows nonsensical sizes when another devices accesses the A95XNAS. Not a workable NAS without NTSF. exFat is not recognized at all by the box. I am in no hurry, I can wait for either stock or home grown ROM that can give these capabilities to the box.Last edited by cjeman; 18 June 2019, 02:29.Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
Originally posted by kanzi View Post#Super SU - Super Issue
Super SU bricked my box. after updating binaries and rebooting, I've got now the A95X logo and nothing else
Did u manage 2 unbrick it?
What was the cause of the issue so that even partition reformatting didn't work?
Is it like the actual firmware and recovery don't match?
Originally posted by nskmda View Post
Same problem here.
(You'll also need a USB male-to-male cable to connect your PC to the A95X MAX.)
Originally posted by cjeman View Postdoktorspon. I do have SambaDroid up and running. My difficulty is that the SSD is defined as NTSF and shows 0 bytes for files over 4GB when copied from another source. Adding an existing NTFS drive with 4GB or more videos shows nonsensical sizes when another devices accesses the A95XNAS. Not a workable NAS without NTSF. exFat is not recognized at all by the box. I am in no hurry, I can wait for either stock or home grown ROM that can give these capabilities to the box.
There are currently 3023 users online. 2 members and 3021 guests.
