Sent from my Mi MIX 2S using Tapatalk
A95X Max TV Box - Amlogic S905X2 A8.1 4/64 ROM Dual WiFi Gig Lan BT4.2 + Support 2.5inch SSD / HDD
It is pretty much new device, and it is good buying, but now there is a lot new with drm for Netflix 4k and I'm afraid that it will ruin selling a95x max. If that happens, we won't have much support from community. But if we can get 9.0 update, then I believe we should be happy.
Notification and button bars
If you swipe from top to bottom (I'm using a mouse with left button pressed), you'll not only get the notification bar, but also a button bar across the bottom which has the usual back/home/recents buttons plus a few more buttons (screen snapshot, vol- & vol+, dismiss button). The central ones are standard Android buttons. Click the recents button and you get the normal recents list. Press down on an item and you will be able to split the screen to have two apps on screen at once.
Originally posted by doktorspon View PostAnd I see four round icons at the top of the launcher: the first I don't recognize; the second has SD, but doesn't seem to do anything; the third is a settings button; and the fourth has a cloud, which when pressed asks for a city, but I don't understand what it is. Beside the settings icon, what exactly do the other three do?
Has anyone successfully connected the A95X MAX to a PC? When I plug the box into a PC using a male-to-male USB-A cable, I don't get any response, except for power.
(I couldn't understand why power was still on in the box when I unplugged the power cord, until I realised that it was still receiving current via usb, so I unplugged that as well and the power light went out.)
Is there anything special I need to know about to be able to send ADB commands from my PC to this box?Last edited by doktorspon; 13 March 2019, 04:54.
Hi guys
1-for the issues of BUGs;you should be contact with>>> [email protected]
because of Vendor firms doesnt give us the real manufacturer! so we have to contact with
the Vendor company! WTF
Before as I know that manufacturer is "WeChip" than I found another info that the manufacturer is "Vontar"!
For example,I bought this Box from Geekbuying and in the past when I contacted with them and tell them
some of issues(especially "Advanced Picture Settings" cause of all these settings never worked)
And Geekbuying offer me $ 20 for partial-refund for the lack of "Picture Settings" and we have dealed
They are very smart even genius
So guys pls contact your vendor and explain all those issues,might be it help/work!
2-Internal Bay 2.5" HDD using;if you contacted WesternDigital or Seagate,probably it never power-off(fully)!!!
or at least or might be Disk will stop to work but LED indicator always on(run)!!
>but if you use Toshiba Canvio;after device power-off than HDD stop it than LED indicator goes to Off after
couple if minutes!!(about 2/3minutes) but with WD/Seagate never goes off(LEDs)even if you check the HDD
then its still run.....
I guess Toshiba have some SW or HW supporter for the full power-off action!
I check Toshiba HDD with my TV or BluRay device or PC any other;its always turn off after power off device!
Just it do it within couple of minutes(after device off)
Another example my old 1Tb WD HDD always RUN!!!
3-With the latest FW;March4/2019;Picture Quality comes to more accurate/way better!!
before pinky/reddish tones but now more accuracy! Brightness get it less,so Blacks more accurate
but need more work for this!
Note;"Advanced Picture Settings"might be will not run(fix it) due to SDK factor!(I'v read this from somewhere
but I forgot know from where)
Need "ROM" too,so get the ROM take the BEER
when i power off the box from remote the usb 2.5 hdd led is still on (but i hear no sound from hdd) my question why the led doesnt light off completely,
I asked:
Originally posted by doktorspon View PostHas anyone successfully connected the A95X MAX to a PC?
But anyway, let me try again:
Has anyone tried to connect this box to a PC using a Type-A male-to-male USB cable?
__________________________________
I tried to flash TWRP (link found here: https://androidpctv.com/tutorial-ins...tvbox-amlogic/) with the stock recovery program, but stock recovery gave me an error with TWRP. So I found an app called Flashify which did flash this TWRP replacing stock recovery, but then I couldn't boot to recovery, finally I flashed the original stock recovery I'd backed up and I could boot to stock recovery again. Presumably, that means the TWRP doesn't work with the A95X MAX.
Originally posted by Luko69 View PostCan I use on this box another launcher ? This stock is brutal.
Originally posted by marijan View PostAs said "bergamesk" it is best to use "AirMouse". As I said go to "Settings, Advanced Settings, and Powerkey Definitions" and there you have the option "Sleep now, Shutdown and Restart".
I have marked the "Shutdown" option and when I press the red button on the remote from the box it goes out all over and even the display.
After that, I turn it on again with the red button.
feelulive
I always using/connected ext.HDD(USB3.0) Toshiba Canvio 1Tb
What brand your ext.HDD? and probably Disk stop it after device power-off(as you said that you wont hear any disk spin/voice)
LED indicator;doesnt matter,this happen from HDD HW/SW issue(or at least Disk doesnt react/work when power of and it get
power from device and in fact your device doesnt get it full OFF!!
Note;but my Toshiba HDD full power OFF(no any LED indicator so this LED goes to OFF)
BUT WD/Seagate do not goes LED OFF,always ON
There are currently 2189 users online. 1 members and 2188 guests.
