A95X Max TV Box - Amlogic S905X2 A8.1 4/64 ROM Dual WiFi Gig Lan BT4.2 + Support 2.5inch SSD / HDD
well I always use "Ethernet Connection" with all my boxes even Bluray/Sat Receiver/TVs etc.,
Note;with this latest FW;"Picture Quality" way better previous FWs!! and need a little bit more!
Because all Advanced Picture Settings modes does not work!! So manufacturer must do that
by FW!!!
And now its acceptable level,thanks for that
Originally posted by vjs905x View PostTo be honest I'm satisfied with box. It is fast, doing everything fine, i just don't like how amlogic chipsets do iptv interlacing, even full hd with a great source picture quality is not so good on box...
Sent from my Mi MIX 2S using Tapatalk
Its depend on "Server source"(such as their picture quality) not Internet Speed!!
Some sources(in fact even mostly)worst! Free sources very bad etc.,
So if you wanna very good quality picture you should buy expensive Server!
I'v 2 IPTV Server,one is worst! the other one is kinda good!
And if you use IPTV thru "Sat.Receiver" it should be way better!
Such as mine Sat.Receiver(not Enigma,its OSCam) super picture because of its "KATHREIN"(916)
For better/best Pic.Quality(in the TV Box area) you should bu use RK3399 chipset
Hi Guys,
I am using this box, and I've already added an 1TB HDD exFAT. Despite this I continue to have an error when I try to copy something larger than 4GB.
I am using sambadroid to use my box as a NAS, so while copying larger files I get the error. I tried NTFS and exFAT and the issue is the same. Could it be the sambadroid app limitation/bug??
Hello,
I need to connect my A95X Max to the PC too. I have a music collection (internal SSD) so I need access to add additional albums without having to remove the SSD every time. I?ve being trying for a few days without success. My laptop (Win 7) does not recognize the A95X Max box. I tried different cables, all 4 usb ports and a few other laptops up to Windows 10. Always the same result. The A95X Max box appears as an ?unknown device? at Device Manager. Basically, a driver for this box is missing from Windows. It can?t get the required driver even online. I also tried a few apps that search and update drivers but they can?t get the correct one. Until now I?ll have to remove the SSD each and every time. Please let me know if you have the driver or know where to find it.
Thanks.
The lack of response to this question perhaps indicates 1) everyone is on vacation, 2) the question doesn't make sense, or 3) it's a silly question.
But anyway, let me try again:
Has anyone tried to connect this box to a PC using a Type-A male-to-male USB cable?
__________________________________
I tried to flash TWRP (link found here: https://androidpctv.com/tutorial-ins...tvbox-amlogic/) with the stock recovery program, but stock recovery gave me an error with TWRP. So I found an app called Flashify which did flash this TWRP replacing stock recovery, but then I couldn't boot to recovery, finally I flashed the original stock recovery I'd backed up and I could boot to stock recovery again. Presumably, that means the TWRP doesn't work with the A95X MAX.[/QUOTE]
There are currently 2562 users online. 2 members and 2560 guests.
