The makers of this box have done some strange things. I can't find a way to connect the box to a PC via USB cable, so I can't use ADB commands. I couldn't flash TWRP because of a verification error that no-one gets on other TV boxes. And we can't ask them technical questions.
A95X Max TV Box - Amlogic S905X2 A8.1 4/64 ROM Dual WiFi Gig Lan BT4.2 + Support 2.5inch SSD / HDD
Has anyone succeeded in registering at https://4pda.ru/forum. I can't finish the registration process because I can't complete the check which asks for a number of letters/numerals with an image of a series of Cyrillic letters. I don't know how to give it the information it wants. Ideas?
Hi I have put in a ssd which is all up and running but I'm not experienced enough to change the place to record from internal file onto a new file on the ssd it keeps crashing the original was something like
Storage/emulated/0/..... If I try and change it to ssd it picks up Storage / the hard drive// folder... Any help would be appreciated.
Originally posted by lardybarstow View PostHi I have put in a ssd which is all up and running but I'm not experienced enough to change the place to record from internal file onto a new file on the ssd it keeps crashing the original was something like
As some background... when I installed my SSD, all I had to do was tell settings about it (under Storage), saying I didn't want to make it internal storage.
For Android, it is located, along with my external SD-card, in /Storage with a reference format of XXXX-XXXX, for example S90B-A76V (at random), so you should find it in this case as /Storage/S90B-A76V. You can check it with Root Browser, which comes installed on the A95X MAX. I generally use ES File Manager to move files and the SSD appears as a local device in the side menu. (ROM storage is located at /Storage/emulated/0/)
Now, you say the SSD is up and running, so the installation sounds successful. It just now dawned on me that you want to record a video and need to change the location you want the file recorded...
I assume you are using Go Recorder (the installed app for recording stuff). When you open the app, you've clicked on the three bars icon in the top left, which opens a menu where you select Workspace and you get a folder display that allows you to choose your storage location. Here you get out of /Storage/emulated/0/ by clicking the topmost folder (marked ..) twice to get to /Storage where you can select your SSD as the recording destination.Last edited by doktorspon; 06 May 2019, 06:53.
Hi doktorspon thank you for that have now managed to move my iptv and screen recorder to the ssd I'm just playing now with othe apps and trying different media players for sound which is missing such as vlc player which I thought would solve it I think it's a case of trying different players but for now my file transfer to ssd seems to be fine many thanks for your advice.
Originally posted by lardybarstow View Posttrying different media players for sound which is missing
Hi Guy
I just bought my second A95x MAX and when I connected the ethernet cable it does not recognize the connection nor it works.
I can see the green and yellow lights on the port working, and so on the router port, but the OS does not connect.
I tried to reset the Connection , but only the WIFI works
is this a problem?
the build up firmware is A85x_MAX-8.1.0-201903011658
kernel 4.9.76
thanks
L
-check your cable! with another devices once more
-check your ethernet cable head where its well connected to your Box!!!
Note;for some times I got this issue! such as connection led lights are ON but ethernet system does not work!
I always to do this>>>check cable head to push it to the port tighten!! than its work
Note;on the Modem side/end that there is no any issue,so the issue occurs with Box ethernet port(so push it
tight)
If possible change your Ethernet cable!! than try it once more
Did anyone install this update?
https://4pda.ru/forum/index.php?s=&showtopic=937561&view=findpost&p=8539 5294
I have the same error message.
https://4pda.ru/forum/index.php?show...ost&p=85460913
I bought this unit to be an inexpensive NAS/DLNA server. Having three 3.0 USB ports, the unit looked right for it. However, NTSF is a non-stater on the unit and home screen cannot be changed. I have a UGOOS UTS3 that has Android 7.1.2 and NTSF is not an issue. If it had 3.0 USB ports, it would be a NAS. Using Macrodroid to load HALauncher when default Launcher kicks in is a short term fix, at best.
I'd be willing to Beta test a ROM that gives me these things.
Home Screen Update: Found this: Settings/Advanced Settings/More Settings/Apps & Notifications/New Launcher App/Home App.Last edited by cjeman; 04 June 2019, 20:17.Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
[ROM] atvXperience v3 - Oreo 8.1 (A95X Max Edition)
https://forum.atvxperience.com/viewt...hp?f=19&t=1043
Originally posted by Leoben View Post[ROM] atvXperience v3 - Oreo 8.1 (A95X Max Edition)
There are currently 3899 users online. 0 members and 3899 guests.
