A95X Max TV Box - Amlogic S905X2 A8.1 4/64 ROM Dual WiFi Gig Lan BT4.2 + Support 2.5inch SSD / HDD
Originally posted by overripe View PostI have a a95x max I would like to put oz weather & bom rader on it I have to download estuary skins & put the file 720p or xml folder in your local skin installation folder but where is this folder I tried winscp & putty a95x dose not seem to want to connect to computer can anny one help
Originally posted by overripe View Postif u want to set up in estuary u have to set up with there skins so u can have rader for your location any way I think I have a way to go through through Ethernet thank u very much
(An estuary is the mouth of a river! Skinning only changes the appearance of an app. Ethernet is a type of network connection. So I still don't understand how any of this affects how an app functions, or doesn't function.)
Originally posted by sashaz300 View PostHi
I did a reset factory my a95x max , and now my device not work bluetooth
there is any solution?
I'm thinking about buying this a95x max but as I read it has encrypted bl and it's not possible to install ROMs on it. Is it depends anything? Because I read there are ROMs for this device.
Is it solved yet or what is the current status?
I'd like to know about everything before buying.
Thanks a lot
Originally posted by doktorspon View Post
You can use stock A95X MAX + Sambadroid to run it as a NAS box. If you need a push, watch this YouTube video. I'm running a Kingston SSD via ethernet using Sambadroid without any trouble.
connecting to //SAMBADROID: Υου can't connect to the file share because it's not secure. This share requires the obsolete SMB1 protocol, which is unsafe and could expose your system to attack. Your system requires SMB2 or higher. For more info on resolving
this issue, see: httρs://go.microsoft.com/fwlink/?linkid=852747 (error 384)
this comes back from Goodsync
Finally i begin to use the box, i didnt delete tvmc kodi, good thing it has true hd and dts hd support but didnt try with my avr yet...
bad thing i cant set up subs color and punto
edit: i noticed it was not on expert mode so switced to expert and sub options okLast edited by feelulive; 28 July 2019, 11:43.
Can anyone understand what Rocco86 is saying and did he answer my questions?
If your PC has no trouble with your Genesys drive, try this:
1. copy any important files to the PC,
2. reformat the Genesys drive using exFAT
3. test with A95X MAX (corrupt?)
4. if no problems, replace your original files on the drive....
I did make the mistake initially of installing the drive as Internal instead of External and then I removed the drive without ejecting it with the droid unpluggedYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hi everyone, not only this is my first post, this is my first time ever owning an Adroid box, and the one I jsut purchased is A95X Max. I've been watching movies with blu-ray discs for 12 years.
Got a question for the experts here, my audio receiver is an older one that doesn't decode DTS-HD MA or Dolby TrueHD, but accepts PCM 5.1 via HDMI. This means I will have A95X Max to decode into PCM 5.1 and sends to the receiver. So I set the channels to 5.1, best match and turn off audio passthrough in Kodi. However, my receiver is only getting PCM 2.0. Any idea why?
In the box settings, there is option for PCM and Raw HDMI, I wonder if I should set it to Raw HDMI but that really sounds like bitstream/passthrough (at work now, just thought about it so I can only test when I get back).Last edited by aiman04; 01 August 2019, 02:40.
Hello to all.
My first post and my first android box. Just got it 2 days ago. A95X Max 4G/64G.
My first impressions are that it is a really good box.
I have noticed in some screenshots that the box temperature is showing at the top of the screen. Mine doesn't have that. Is there any tool/link to put it up there?
I don't have an air mouse. I tried a wireless USB microsoft mouse I had at home but it didn't work, so I basically use the remote app on my phone, together with the remote. The phone is really bad for scrolling, which I resort for the remote to do it. Other things I'm unable to bring up is the top notification bar and the bottom tool bar.
Any tips on these?
Thanks!
Originally posted by aiman04 View PostHi everyone, not only this is my first post, this is my first time ever owning an Adroid box, and the one I jsut purchased is A95X Max. I've been watching movies with blu-ray discs for 12 years.
Been tweaking for days, both the OS and the player apps. Used so many different types of player apps, all failed to output PCM 5.1. All players have problem playing 4k, Kodi was a hit and miss while others failed to even play. Blu-ray ISOs not working. I can't get all of them to output video at their native frame-rate also, you can't even change manually. They also crashes regularly.
And the Android OS itself, I've never used it ever so maybe I'm just not familiar but I learned a lot in a few days. But it was a bad introduction, the user experience was highly frustrating, very difficult to navigate through everything. A pain going through a web browser or even Google Play. My Harmony remote can only do as much as the original remote. I bought the air mouse because I thought it would help, but it didn't.
The OS has potential but it's seriously lacking finesse. It is littered with bugs. There is always something not working that I have to spend time to troubleshoot, app installation keep failing, external USB disk not recognized, etc. I managed to fix them, but I can't spend my time every day fixing stuffs. This is not a computer (even then it should not misbehave), I bought it to enjoy my movies.
I ended up using my Windows laptop that has an HDMI out. Installed K-Lite codecs with MPC-HC, a little settings got it to decode everything and output PCM 5.1 (6.9 Mbps). Until I get a new receiver that will do just great. Installed a tiny third party app to set the frame-rate to the movies native automatically. The MPC-HC plays everything smoothly except blu-ray menu, which is fine as don't really need it. But I need the menu to calibrate the AV using Disney WOW AV calibration tool so I installed VLC just for that (not gonna pay for a professional calibrator yet). And voila, the video and audio quality is now just as good as my blu-ray player! I'm gonna go ahead and rip the rest of my blu-ray discs, they're no longer just for backup but now I can watch them while keeping the physical discs in the shelf (the original intention for this whole project).
The laptop now sits with lid closed in my home theater with 4 external USB disks totalling 11 TB (for now). I'm a now a very happy person. Put the Android box in the living for my wife to watch some IPTVs and and the kids to watch Youtube.
I would like to thank everyone because honestly I've learned a lot here and in other forums. But sadly this is goodbye. I've officially gave up on this box, and Android altogether.
Cheers,
Iswardi
Got the a95x max v81. Was able to install atvxperiance. Lost Bluetooth, no connection. Went back to stock. Still no Bluetooth connection. Wiped data and cache factory reset several times. Still no Bluetooth. Won't stay on or connect. Can someone please help me find the files I need for either stock or atvx v3a v81. Thanks in advance. Love this box and I run atv launcher pro on stock. Bit I do like atv Oreo UI. Thanks in advance
Sent from my ASUS_X017DA using Tapatalk
There are currently 2532 users online. 0 members and 2532 guests.
