Mecool M8S PRO L Netflix error tvq pb 103 (2.10.0)
Originally posted by mymo View PostOT: Just out of curiosity, in what case is Coreelec better than the Shield? Unfortunately I don't own a Shield but I thought it was the perfect device... I have a S905x device with Coreelec, and I'm wondering what it can run better than a munch more expensive box
I guess to answer your questing simply, depending upon your needs, and apps that you use, the Shield WILL replace your CoreELEC box.
I have a 65" Samsung 4k TV, and a mid-range Yamaha AVR that plays ALL the audio codecs, including the HD audio codecs.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
The Shield is about 97% perfect, but still has some issues. I don't recall which movie I was trying to watch on it yesterday (hell to get old), but it had minor jerkiness. I had to switch to my CoreELEC box. As you are aware, CoreELEC will play ** EVERYTHING **. My movies have a variety of different encoding formats, and only my Zidoo X9S and my Shield will play all of them natively. None of my Amlogic boxes running Android will play my movies encoded with the VC-1 codec,but these boxes running LibreELEC or CoreELEC will play them flawlessly.
Originally posted by paposeco View Post
Wouldn't Plex for example with the transcoding option, should you use it, theoretically sort that out?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I don't recall which app I tried to play it with. With my Shield, I primarily use Emby for my media play back. I have the Plex pass, but rarely use Plex.
There are only 3 AndroidTV devices compatible with Netflix now and they are the Nvidia Shield, Xiaomi Mi and Jetstream 4K box.
In some countries, cable tv companies also have their own AndroidTV devices compatible with Netflix 4K if they signed a $5m a year deal with Netflix.
I don't think Mecool will ever have better Netflix again as they are on Google and Netflix's blacklists I guess.
@mo123 from this it looks, however, that more than three - https://en.wikipedia.org/wiki/List_o...atible_devices
There are currently 2235 users online. 0 members and 2235 guests.
