Now I'm planning to install twrp and install the stock remote patch.
T95Q Amlogic S905X2 Android 8.1 4GB DDR4 64GB Dual Band WiFi LAN BT USB3.0
A new Android 9 rom by ALVATECH:
https://forum.freaktab.com/forum/tv-...9-0-pie-s905x2
Tested with my T95Q
everything works fine. ....
(use 95x2 rom)
only LED is always on, but who cares..
Patch for T95Q and X96Max to control the serial remote control ->
(install with TWRP )
https://drive.google.com/file/d/15W-...ew?usp=sharing
Tested with my T95Q
(use 95x2 rom)
Tested with my T95Q
(use 95x2 rom)
Can anyone explain, in a bit of detail, how to install the patch to solve the problems with the T95q serial remote control? I've tried to install it from TWRP, but the system does not detect the SDcard. Somewhere I've read that you have to go back to the original TWPR, but I have not been able to do it either. I'd be very grateful that someone put some clue in order to finish installing everything. Thank you.
Originally posted by JBG View Post
Hi.
if u cant install with twrp just unzip the patch, then open the folder vendor/etc and copy the file "remote-mouse12.tab" to vendor/etc of ur root ( with a root browser).
Thank you very much for being so kind.Last edited by JBG; 05 November 2019, 01:10.
Thanks Mojojojo67. I've followed your instructions and I've get to install the patch. Now I'm going to test the TVBox T95q with Alvatech's firmware. In my first tests I saw that the ON button doesn't work very well.
all are working as stated.
i tried to fix the ON button for the stock remote.
i tried the SU command but it did not work for me.
what i did was, instal terminal and gave it root access.
execute the commands. execute successfully.
exit terminal, open xplore with root access.
verify /dev/block/bootloader but no change.
size and date remained untouched.
i tried to flash this full patch but when i got into TWRP the zip file is not showing in the sdcard folder.
what did i missed? thanks for your guidance!Last edited by raptur3d; 05 November 2019, 17:05.
Originally posted by raptur3d View Post
i flashed Sasvlad's ATV 2.0 Rom and remote patch.
Hey guys, what is the best method for getting this box recognised in Windows ? no joy so far, I have ordered a new male to male cable just in case it's faulty, I doubt it, becuase this kind of issue has happened before with new retail cables on other boxes, are you guys using the power brick ? before i remember one problem was low power error on an older box I had.
Originally posted by somenutter View PostHey guys, what is the best method for getting this box recognised in Windows ? no joy so far, I have ordered a new male to male cable just in case it's faulty, I doubt it, becuase this kind of issue has happened before with new retail cables on other boxes, are you guys using the power brick ? before i remember one problem was low power error on an older box I had.
There are currently 2082 users online. 0 members and 2082 guests.
