T95Q Amlogic S905X2 Android 8.1 4GB DDR4 64GB Dual Band WiFi LAN BT USB3.0
Originally posted by Appdata View Postdid you keep the reset pressed while connecting thew usb?
2.connect USB 2.0 make cable to PC 3. start program
4. Press reset button in Av socket
5. Power On. (Press reset button)
Before install already driver USB burning program computer not see. my PC if any USB device notifications voice, but box nothing
Originally posted by stranula View PostI've tried several different roms on this device and can only get CDDA 2.0 audio out via HDMI or optical. Anyone get 5.1 audio out of this device?
I had 5.1 sound via spdif with this version.
Unfortunately 5.1 sound does not work on version 2 anymore.
XTMOD U211 Hi folks i'm here to present you one of my last public works. If you're used to my roms should be very familiar ;) It's based on a mix of firmwares and i took the best from every official firmwares published, most of the vendor partition is compiled just for this fw. I do not use stupid old fashioned
Originally posted by JandeHekkerman View PostHave you tried the Xannytech rom version 1?
https://r.tapatalk.com/shareLink?url...7&share_type=t
Originally posted by abhi98228 View PostHow do I install stock recovery back after I have installed TWRP?
Can I install Android TV rom in this tv box? I have found some roms in this forum but not sure if it works.
before u try to install any rom !!
(so u always can restore )
if u wanna flash back to
Stock recovery for S905x2 ->
https://mega.nz/#!2mZmlADL!dkKVceGi1...g7dX40E2QmUuMk
(just install with twrp....)
Originally posted by mojojojo67 View Post
First do a backup with TWRP
There are currently 1949 users online. 0 members and 1949 guests.
