Sent from my Pixel 2 XL using Tapatalk
T95Q Amlogic S905X2 Android 8.1 4GB DDR4 64GB Dual Band WiFi LAN BT USB3.0
Can I just switch out the remote config files to get the remote working?
The remote will work when you use the XannyTech rom for u211 devices.
XTMOD U211 Hi folks i'm here to present you one of my last public works. If you're used to my roms should be very familiar ;) It's based on a mix of firmwares and i took the best from every official firmwares published, most of the vendor partition is compiled just for this fw. I do not use stupid old fashioned
Originally posted by vropers View PostSomeone have link for site with full instruction(step by step) how to flash firmware(using amlogic burning tool) on this box? Thx
Originally posted by vropers View PostI know procedure in amlogic USB burning tool but i dont know what i must do in box ? I mean to for example in x92(we must push reset button when connect with pc) and for 95q what i must do it?
Yeap thanks for the constructive answer. Having the IP of your box changing often, creates a bunch of problems when using FTP, ssh or Yatse.
I would prefer if you could verify if it's indeed a firmware issue or not so that I can look for another solution.
Thanks though, really appreciate the answer
My T95Q also rebooted itself 5 -10 times a day with the stock firmware. I was able to reduce the number of reboots by installing the Xannytech rom for u211 devices. After installation I disabled all unnecessary background services. What apps are you using? One of my apps that runs as a background service (FolderSync), sometimes causes a reboot.
I'm still facing spontaneous reboots but only 1-3 times a day.
There are currently 3835 users online. 2 members and 3833 guests.
