T95Q Amlogic S905X2 Android 8.1 4GB DDR4 64GB Dual Band WiFi LAN BT USB3.0
Originally posted by R7UST View Post
Might give it a try. Cheers
(use the 95x version) ->
https://forum.freaktab.com/forum/tv-...ad-android-9-0
for me the best Android 9 rom for T95Q at the moment.
(big tnx to sasvlad..)
mojojojo67: Thanks, this rom works nicely. Special thanks too: sasvlad OT, May test it on a Meecool KM9 as their stock Android 9 firmware really sucks
Patch for T95Q and X96Max to control the serial remote control (Android 9 rom)->
(install with TWRP ) ->
new Patch
(turn the box off and on! )
with new bootloader, now the patch is complete...
now the IR-remote is working for me...
(big tnx to sasvlad)Last edited by mojojojo67; 06 September 2019, 14:44.
mojojojo67
[QUOTE=mojojojo67;n780412]Patch for T95Q and X96Max to control the serial remote control (Android 9 rom)->
(install with TWRP ) ...
What TWRP do you recommend? I currently have 3.2.3-1 and this one doesn't see any partitions under this Android 9
[QUOTE=JKow;n780433]mojojojo67
Originally posted by mojojojo67 View PostPatch for T95Q and X96Max to control the serial remote control (Android 9 rom)->
(use 95x rom)
or try this android 9 TWRP ->
https://drive.google.com/file/d/1D-R...ew?usp=sharing
Hello my friends i have same your problem with t95q android 8.1 .....rom t20008....my box don' t upldate play store and crash my app in play store when i click on their... you have solved or have changed box? I tried all roms on internet but ...nothing...have always problem. The box works fine but don t upload play store and crash when i click on 1 application on my app ... for all rest works fine.
i needet to know if os only my problem or is a problem of all t95s.
thanks
p.s. i see that there are for some applications 2 installation possibility : android and android tv...for example youtube have 2 youtube installed in it...google...kodi...mmmm i dont understand.
very thanks
theres another T95Q Android 9 rom (by sasvlad) with working WIFI
Originally posted by gatos814 View PostStock firmware here :
https://mega.nz/#!LttAzCwQ!C2jAILkbL...r_TsXK7iqfS-xE
Is this link the best/most stable version to get my box back to being bog-standard??
Originally posted by ch1vph View Post
Hello! Sunvell sent me Andriod 9 update so I could turn off the LED light...but WiFi gone!
Originally posted by Jeffers View Post
Can't answer your question, but once you get back to where you want to go, I think you can open the box and unplug the led or whatever it is that generates the light.plus I do like LED just not at night behind my TV where the remote doesn't reach
There are currently 1970 users online. 0 members and 1970 guests.
