O CUAL TWRP ME RECOMIENDAN?
M8S PRO W-userdebug 7.1.2 NHG47L 20180724.093649.v0213, Blue Board: M8S_W_REV2.2
Hello,Finally i had this box with blue board.I bricked and unbricked with rom M8S_PLUS_W 20180622.img.I flashed with Burning Tool and my box open.After i go to flash the ATV rom and i got an error from stock recovery.Can you help me ? I flash recovery from post #27 but didn't work.Then i flashed the recoverys905w which in the same folder.I can't wipe after that.Any custom rom ?
Sorry for my bad english !!!
Thank you in advanced.
I update Locally to ATV
- in an SD with format FAT32 save the file M8S_PRO_W-ota-20180312.181951.V0213.zip and recovery.img (I do not know if recovery.img is good for something)
- Enter to update locally and choose the M8S_PRO_W-ota-20180312.181951.V0213.zip file. check Wipe media and wipe data.
- After it was turned on, it was updated again and updated by OTA. and Wipe media and wipe data.
ATV review:
* is Root
* Android TV works.
* WIFI works well. good sign.
* IR Remote Control works fine.
* Youtube works in HD
* Kodi works well
* hdmi mhl works well.
* Cetus server works well
* Android TV Launcher has some delays, on the main screen of ATV. (Could be for the interative suggestions)
* Remote Control Google, no works not detected by the cell phone (I tried it but at that time I had removed the root.) After factory reset, it has not worked.
* Netflix TV, does not work error (-100). probe all the old versions and some modified ones. I'm reviewing
* Netflix HD works well but is not compatible with remote control you have to use mouse.
Anyone have any suggestions for the error of the Netflix TV and the Google Remote Control?
Originally posted by colbaip View PostBrand: MECOOL
Model: M8S PRO W
Version BOARD : M8S_W_REV2.2 2018-09-20
BOARD COLOR: BLUE
CHIP WIFI:SVG051G
CHIP FLASH: PFC54 -10AL 1744
BOTON RESET: NO
LABEL: M8S PRO W 2G 16G DDR3 DV
WIFI ANTENNA: Dipolo
ROM STOCK : M8S PRO W-userdebug 7.1.2 NHG47L 20180724.093649.v0213
Picture:
!!!!!! IMPORTANT !!!!
++++++ I am collecting information on this model of M8S REV2, I have not done tests yet. please share your experience to be clear about what modifications we can make on this TVBOX.
With the information posted, I will update post # 1.
Sorry for my English. ++++++
ROM STOCK :
M8S PRO W-userdebug 7.1.2 NHG47L 20180724.093649.v0213 (ZIP | Link) post#1
* ROM STOCK
* NO ATV
* Update por SD o USB
* Tested by denexo takizzz
M8S_PRO_W-ota-20180802.182556.V0213 (ZIP | Link)
* ROM STOCK
* NO ATV
* Tested by chillywillyfree
M8S_PRO_W-ota-20180312.181951.V0213 (ZIP | Link)
* ROM STOCK
* ATV
* Tested by geotzia takizzz
ROM RECOVERY :
M8S_PLUS_W 20180622.img (IMG | Link)
* ROM M8S PLUS
* NO ATV
* USB Burning Tool
* Tested by takizzz geotzia
Unbrick M8S BLUE BOARD M8S_W_REV2.2: Informed by takizzz
1. Download M8S_PLUS_W 20180622.img (IMG | Link)
2. Flash USB_Burning_tool with M8S_PLUS_W 20180622.img
3. Update With SD M8S PRO W-userdebug 7.1.2 NHG47L 20180724.093649.v0213 (ZIP | Link) or with ATV M8S_PRO_W-ota-20180312.181951.V0213 (ZIP | Link).
Hello, Thanks for the information.
I have donwloaded the firmware M8S_PRO_W-ota-20180802.182556.V0213 and my M8S Pro W was upgrade succefully, this version is Android TV version, according your description this SW version is NO Android TV. Could you confirm if exist a version M8S_PRO_W-ota-20180802 NO Andrid TV?
Thanks in advance.
Also it seems Guest has updated his nexus build for Mecool M8s Pro W. I wonder if we can use the february 2019 build in this link https://forum.freaktab.com/forum/tv-...om-android-7-1 to update our TV Box and get Netlfix HD working on the our new model. Thanks
but my computer not recognize any new device
AMIGAnTOMEK try with different usb cable and different usb slots on the pc...also make sure you have installed the drivers from usb burning tool...you don't need the reset pins
There are currently 2729 users online. 0 members and 2729 guests.
