M8S PRO W-userdebug 7.1.2 NHG47L 20180724.093649.v0213, Blue Board: M8S_W_REV2.2
It appears stock version of the new magendaz created build for our model is working as mentioned in the post https://forum.freaktab.com/forum/tv-...857#post763857 However, TWRP is having some problems and hence OTA file of the new magendaz firmware build is not working. Netflix HD working or not, is till not confirmed anywhere.
Hi I have a M8S Pro W with this hardware revision 2.2. I followed the procedure and was able to install the rom and to launch it. However I am facing issues with the wifi. It seems like the wifi is not starting and the it is not listed in the interface list (I checked that in a terminal).
Is anyone facing this issue.
If it can help, my wifi chip is different from the one mentionned in the first post. Mine is SVG051P instead of SVG051G.
I have a problem bit related to this board, tried to update device but something went wrong and now I have a brick, tried usb burning tool but it always gets stuck at 4%, tried different images with no luck, board isn't detected by holding reset, only when I short nand pads.
LOG:
[10:47:54 038][Global][Inf]--Burning thread HUB7-1 start
[10:47:54 088][HUB7-1][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&1af375c&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000674
[10:47:54 138][HUB7-1][Inf]--Connect path=Rozszerzony kontroler hosta USB2 Intel(R) ICH9 Family - 293A/P0/P0
[10:47:54 138][HUB7-1][Inf]--Start burning...
[10:47:54 188][HUB7-1][Inf]--------------ERASE BOOTLOADER------------
[10:47:54 188][HUB7-1][Inf]--2-4-0-0
[10:47:54 188][HUB7-1][Inf]-------------Download DDR.USB-----------
[10:47:54 189][HUB7-1][Inf]--2-4-0-0
[10:47:54 189][HUB7-1][Inf]--Control write pll reg1 0xd9000000:0x000000b1
[10:47:54 690][HUB7-1][Inf]--Control write pll reg1 0xd9000000:0x00005183
[10:47:55 191][HUB7-1][Inf]--Write initial succeed
[10:47:55 191][HUB7-1][Inf]--Upload encrypt at 0xc8100228
[10:47:55 191][HUB7-1][Inf]--ulValue = 0xadfc318c
[10:47:55 191][HUB7-1][Inf]--Read encrypt value succeed
[10:47:55 200][HUB7-1][Inf]--Transfer complete
[10:47:55 201][HUB7-1][Inf]--Run at address 0xd9000000
[10:47:55 202][HUB7-1][Inf]--RunInRam succeed
[10:47:55 266][HUB7-1][Inf]--2-4-0-0
[10:47:55 266][HUB7-1][Inf]--CheckFileRunState succeed
[10:47:55 267][HUB7-1][Inf]--runResult:0x 0,paraMagic:0x7856efab
[10:47:55 267][HUB7-1][Inf]--ddrCapacity:0x 800
[10:47:55 267][HUB7-1][Inf]-------------Download UBOOT.USB-----------
[10:47:55 267][HUB7-1][Inf]--2-4-0-0
[10:47:55 267][HUB7-1][Inf]--ulValue = 0xadfc318c
[10:47:55 267][HUB7-1][Inf]--Download DDR.USB buffer at 0xd9000000
[10:47:55 276][HUB7-1][Inf]--Transfer complete
[10:47:55 276][HUB7-1][Inf]--Download UBOOT.USB buffer at 0x0200c000
[10:47:55 413][HUB7-1][Inf]--Transfer complete
[10:47:55 417][HUB7-1][Inf]--DownCheckPara succeed
[10:47:55 417][HUB7-1][Inf]--Run at address 0xd9000000
[10:47:55 478][HUB7-1][Inf]--ReadCheckPara succeed
[10:47:55 478][HUB7-1][Inf]--Download DDR.USB buffer at 0xd9000000
[10:47:55 488][HUB7-1][Inf]--Transfer complete
[10:47:55 488][HUB7-1][Inf]--DownRunPara succeed
[10:47:55 488][HUB7-1][Inf]--Run at address 0xd9000000
[10:47:55 989][Global][Inf]--Catch DBT_DEVICEREMOVECOMPLETE
[10:47:55 990][Global][Inf]--Scan usb device
[10:47:55 990][Global][Inf]--Aml scan WorldCup Device
[10:47:55 992][Global][Inf]--Host: Uniwersalny kontroler hosta USB Intel(R) ICH9 Family - 2934
[10:47:55 993][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_2934&subsys_30e7103c& rev_03#3&21436425&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:47:55 993][Global][Inf]---->Roothub:USB#ROOT_HUB#4&1bfecf0b&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:47:55 993][Global][Inf]-------->[Port0]NoDeviceConnected
[10:47:55 993][Global][Inf]-------->[Port1]NoDeviceConnected
[10:47:55 994][Global][Inf]--Host: Uniwersalny kontroler hosta USB Intel(R) ICH9 Family - 2935
[10:47:55 994][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_2935&subsys_30e7103c& rev_03#3&21436425&0&e9#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:47:55 994][Global][Inf]---->Roothub:USB#ROOT_HUB#4&68f8698&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:47:55 994][Global][Inf]-------->[Port0]NoDeviceConnected
[10:47:55 994][Global][Inf]-------->[Port1]NoDeviceConnected
[10:47:55 995][Global][Inf]--Host: Uniwersalny kontroler hosta USB Intel(R) ICH9 Family - 2936
[10:47:55 995][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_2936&subsys_30e7103c& rev_03#3&21436425&0&ea#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:47:55 995][Global][Inf]---->Roothub:USB#ROOT_HUB#4&389948a1&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:47:55 995][Global][Inf]-------->[Port0]NoDeviceConnected
[10:47:55 995][Global][Inf]-------->[Port1]NoDeviceConnected
[10:47:55 996][Global][Inf]--Host: Uniwersalny kontroler hosta USB Intel(R) ICH9 Family - 2937
[10:47:55 996][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_2937&subsys_30e7103c& rev_03#3&21436425&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:47:55 996][Global][Inf]---->Roothub:USB#ROOT_HUB#4&1e55bd4c&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:47:55 999][Global][Inf]-------->[Port0]Other device
[10:47:55 999][Global][Inf]-------->[Port1]NoDeviceConnected
[10:47:56 000][Global][Inf]--Host: Uniwersalny kontroler hosta USB Intel(R) ICH9 Family - 2938
[10:47:56 000][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_2938&subsys_30e7103c& rev_03#3&21436425&0&d1#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:47:56 000][Global][Inf]---->Roothub:USB#ROOT_HUB#4&33c505bf&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:47:56 004][Global][Inf]-------->[Port0]Other device
[10:47:56 004][Global][Inf]-------->[Port1]NoDeviceConnected
[10:47:56 004][Global][Inf]--Host: Uniwersalny kontroler hosta USB Intel(R) ICH9 Family - 2939
[10:47:56 005][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_2939&subsys_30e7103c& rev_03#3&21436425&0&d2#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:47:56 005][Global][Inf]---->Roothub:USB#ROOT_HUB#4&3fb53b9&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:47:56 005][Global][Inf]-------->[Port0]NoDeviceConnected
[10:47:56 005][Global][Inf]-------->[Port1]NoDeviceConnected
[10:47:56 005][Global][Inf]--Host: Rozszerzony kontroler hosta USB2 Intel(R) ICH9 Family - 293A
[10:47:56 005][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_293a&subsys_30e7103c& rev_03#3&21436425&0&ef#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:47:56 005][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&11358f7e&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:47:56 006][Global][Inf]-------->[Port0]NoDeviceConnected
[10:47:56 006][Global][Inf]-------->[Port1]NoDeviceConnected
[10:47:56 006][Global][Inf]-------->[Port2]NoDeviceConnected
[10:47:56 006][Global][Inf]-------->[Port3]NoDeviceConnected
[10:47:56 006][Global][Inf]-------->[Port4]NoDeviceConnected
[10:47:56 006][Global][Inf]-------->[Port5]NoDeviceConnected
[10:47:56 007][Global][Inf]--Host: Rozszerzony kontroler hosta USB2 Intel(R) ICH9 Family - 293C
[10:47:56 007][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_293c&subsys_30e7103c& rev_03#3&21436425&0&d7#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:47:56 007][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&cd44436&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:47:56 007][Global][Inf]-------->[Port0]NoDeviceConnected
[10:47:56 007][Global][Inf]-------->[Port1]NoDeviceConnected
[10:47:56 007][Global][Inf]-------->[Port2]NoDeviceConnected
[10:47:56 007][Global][Inf]-------->[Port3]NoDeviceConnected
[10:47:56 007][Global][Inf]-------->[Port4]NoDeviceConnected
[10:47:56 007][Global][Inf]-------->[Port5]NoDeviceConnected
[10:47:56 007][Global][Inf]--Scan USB host controller complete
[10:47:56 007][Global][Inf]--Update data center with HubMap
[10:47:56 007][Global][Inf]--Update hub7 device data
[10:47:56 007][Global][Inf]--Update HUB7-1
[10:47:56 007][HUB7-1][Inf]--Update device path
[10:47:56 007][Global][Inf]--Update HUB7-2
[10:47:56 007][HUB7-2][Inf]--Update device path
[10:47:56 007][Global][Inf]--Update HUB7-3
[10:47:56 007][HUB7-3][Inf]--Update device path
[10:47:56 007][Global][Inf]--Update HUB7-4
[10:47:56 007][HUB7-4][Inf]--Update device path
[10:47:56 007][Global][Inf]--Update HUB7-5
[10:47:56 007][HUB7-5][Inf]--Update device path
[10:47:56 007][Global][Inf]--Update HUB7-6
[10:47:56 007][HUB7-6][Inf]--Update device path
[10:47:56 039][HUB7-1][Inf]--Device is removed
[10:48:06 040][HUB7-1][Inf]--Detect Device connect timeout
[10:48:06 040][HUB7-1][Inf]--Close device handle 0x00000674
[10:48:06 090][HUB7-1][Err]--Device path is null or device connect status is error
[10:48:06 145][HUB7-1][Err]--[0x10302001]Romcode/Switch status/Check connect/Enum device error
Hello, another disillusioned owner of M8S Pro W ver2.3 here (well, overheating, bad wifi reception, general sluggishness of the system).
I've been wanting to test Guest 's latest nexus nano on my device, but before installing it for good I wanted to give it a 'test drive' by running it off either USB or sd card.
I've spent many hours scouring through freaktab (and elsewhere) for solution on dual booting (emmc / sd) without installing. There were options such as u-boot, libreelec, linux distros of all flavors, but no conclusive and definite answer as to whether this is possible and how it's done.
AFAIK, the key is in prepping the sd card with bootable code (so to speak) and then raw copying .img to it.
If any kind soul would be willing to share more detailed instructions (and tools) on dual booting, I'd be more than grateful.
Originally posted by ScApi View Post
can some one help us ?
thx!
M8S_PRO_W-ota-20190104.104600.V0213.zip
Tested v0213 factory firmware for blue mainboard, flashing over system or factory recovery from SD or USB
This update limits the whole system to 720p for better CPU temperature.
pure android, no more crashes
Thanks a lot for the new firmware.
Could you inform us if this firmware M8S_PRO_W-ota-20190104.104600.V0213.zip is for Android TV model (With voice control) or is for no Android TV Model (without voice control)
Thanks again for your supportBrand: MECOOL Model: M8S PRO W Version BOARD : M8S_W_REV2.2 2018-09-20 BOARD COLOR: BLUE CHIP WIFI:SVG051G CHIP FLASH: PFC54 -10AL 1744 BOTON RESET: NO LABEL: M8S PRO W 2G 16G DDR3 DV WIFI ANTENNA: Dipolo ROM STOCK : M8S PRO W-userdebug 7.1.2 NHG47L 20180724.093649.v0213 **************************************************
For some reason no firmware works by flashing through the installer...If I use the one from 201803 it says it can't install because It is older than the one installed. All the other ones give me an error 7 saying they are for m8s pro w and this device is a plus W (which is not). How to solve this??
Originally posted by Freddydq View Post
Hello, Thanks for the information.
I have donwloaded the firmware M8S_PRO_W-ota-20180802.182556.V0213 and my M8S Pro W was upgrade succefully, this version is Android TV version, according your description this SW version is NO Android TV. Could you confirm if exist a version M8S_PRO_W-ota-20180802 NO Andrid TV?
Thanks in advance.
I managed to flash my M8S Plus W with the M8S_PLUS_W 20180622.img and now I am getting the following screen after it boots:
Any idea how I can go past this screen? I connected a keyboard/mouse and I could type on that box,but other than that it seems stuckYou may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoLast edited by billylee; 05 June 2019, 10:20.
There are currently 3517 users online. 0 members and 3517 guests.
