M8S PRO W-userdebug 7.1.2 NHG47L 20180724.093649.v0213, Blue Board: M8S_W_REV2.2
I have this board and i tried to flash from this rom...You may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosLast edited by geotzia; 13 January 2019, 21:20.
I tried videostrong method but cannot rename dates ( not have rights)
That's my case , anyone who can help is welcome. I have wasted too much time but still want to revert it to PRO device
Originally posted by d3ckart View Post
I had bricked mine , couldn't flash anything through usb tool ( stuck at 7% ) and recovered it with mecool plus firmaware. Therefore the device is recognised as a PLUS device and not PRO therefore an error comes up notifying me that cant flash on different device although its the same.
I am in exactically same case... i tried to flash the firmware from #1 post throught updater app but stoped with -error in section 7, installation aborted- as i said above, and the firmware from #2 post its ok but it is ATV not practical at all so i roll back to Mecool Plus firmware
You have to try videostronf method,
In the spirit of the Pure Nexus Project, these TVStock Nexus ROMs deliver the pure Android TV experience using the Open GApps TVStock Package
Ιn my case i couldn't overwrite the dates on the second file and therefore i couldn't flash cause installation stopped when it recognised that the firmware was older than the one already installed.
Has anyone flashed TWRP , and is there any available link?
I tried to flash twrp from https://forum.atvxperience.com/viewtopic.php?t=87 with no luck ( twrp.img is stretched out (only 1/4 the image is shows)
can you tell me when you rescue the box, you use USB_burning_tool with the image M8S_PLUS_W 20180622.img that is in the RAR file?
Hello
the good news are that i found a twrp for our box. You can download the zip file and flash it through update app.Then you have twrp and you can do backup or restore. https://drive.google.com/file/d/1x1b...MZ77Ij-nb/view
The bad news are when you reboot to recovery the box reboot to stock recovery but you can do the same procedure (flash twrp and make restore or ..backup)
Since I couldn' t find a good android rom, I decided to try CoreELEC. I succesfully installed CoreELEC-S905.arm-8.95.7-S905.img.gz using device tree gxl_p281_2g at a microsd and it boots fine from the tf slot of the tvbox.
The only downside is that the wifi is not installed , so only ethernet connection is possible or you have to buy a compatible usb wifi stick.
Kodi is way smoother, no lag at all, cpu temperature is at 60-65 celsius degrees only, after watching a fullHD movie.Last edited by noths; 17 January 2019, 22:04.
There are currently 2701 users online. 0 members and 2701 guests.
