Thanks again for your great support!
M8S PRO W-userdebug 7.1.2 NHG47L 20180724.093649.v0213, Blue Board: M8S_W_REV2.2
Hi, I have a MECOOL M8S Pro W board (Blue Board Rev 2.3, with S905X SoC) ... PC finds the box via USB immediately, no need to short any pins, however, when I try to flash any ROM, it either stops at 1%, or 2% or 4% ... Most ROMs actually stop at 4% and you hear a USB detach sound from the PC. I tried loads of ROMs with no luck, also tried SD Card flashing again no luck. Most probably I don't have the proper ROM or the board is "dead". This all started when I tried to reset the board, as I had dual boot between ARMBIAN and the stock firmware, then the stock firmware was not booting any more but SD Card ok, so I reset the board and then neither SD Card nor stock rom were booting.
Thanks for your help!
Originally posted by colbaip View PostBrand: MECOOL
Model: M8S PRO W
Version BOARD : M8S_W_REV2.2 2018-09-20
BOARD COLOR: BLUE
CHIP WIFI:SVG051G
CHIP FLASH: PFC54 -10AL 1744
BOTON RESET: NO
LABEL: M8S PRO W 2G 16G DDR3 DV
WIFI ANTENNA: Dipolo
ROM STOCK : M8S PRO W-userdebug 7.1.2 NHG47L 20180724.093649.v0213
i see the label say "M8S PRO PLUS 2GB 16GB FLASH ZA " did you know about this differences,
because i have problem with this board partition even its on recovery cannot able to locate where is the sdcard location, its mounting wrong partition,
i also try to use TWRP recovery for M8S PRO PLUS from magendanz post.
i have backup original partitions, if you like take a look i will share it later, need some time to upload .
here are the picture of my board :
stock recovery error :
TWRP recovery error :
is it safe or can fix my issue if flash you rom ?
please need help on this, thanks in advanceLast edited by bullghost; 19 April 2020, 10:53.
Originally posted by geotzia View Post
I have good news and bad news...
the good news are that i found a twrp for our box. You can download the zip file and flash it through update app.Then you have twrp and you can do backup or restore. https://drive.google.com/file/d/1x1b...MZ77Ij-nb/view
The bad news are when you reboot to recovery the box reboot to stock recovery but you can do the same procedure (flash twrp and make restore or ..backup)
Could you re upload the link of this twrp?
My regards.
this is the repport of ubt
[14:12:45 212][Global][Inf]--USB_Burning_Tool soft Version: V2.1.9.0
[14:12:45 212][Global][Inf]--Windows Version: Microsoft Windows 10, Bit: 64
[14:12:45 221][Global][Inf]--Scan usb device
[14:12:45 221][Global][Inf]--Aml scan WorldCup Device
[14:12:45 222][Global][Inf]--Host: Intel(R) 8/C220 USB EHCI N° 1 - 8C26
[14:12:45 222][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_8c26&subsys_06121028& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[14:12:45 222][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&353bfc3e&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:12:45 285][Global][Inf]-------->[Port0]USB#VID_8087&PID_8000#5&23606a80&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:12:45 285][Global][Inf]---------->[Port0]NoDeviceConnected
[14:12:45 285][Global][Inf]---------->[Port1]NoDeviceConnected
[14:12:45 285][Global][Inf]---------->[Port2]NoDeviceConnected
[14:12:45 285][Global][Inf]---------->[Port3]NoDeviceConnected
[14:12:45 285][Global][Inf]---------->[Port4]NoDeviceConnected
[14:12:45 285][Global][Inf]---------->[Port5]NoDeviceConnected
[14:12:45 285][Global][Inf]-------->[Port1]NoDeviceConnected
[14:12:45 285][Global][Inf]--Host: Intel(R) 8/C220 USB EHCI n° 2 - 8C2D
[14:12:45 285][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_8c2d&subsys_06121028& rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[14:12:45 285][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&12e72867&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:12:45 348][Global][Inf]-------->[Port0]USB#VID_8087&PID_8008#5&1ffa69d&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:12:45 348][Global][Inf]---------->[Port0]NoDeviceConnected
[14:12:45 348][Global][Inf]---------->[Port1]NoDeviceConnected
[14:12:45 348][Global][Inf]---------->[Port2]NoDeviceConnected
[14:12:45 348][Global][Inf]---------->[Port3]NoDeviceConnected
[14:12:45 348][Global][Inf]-------->[Port1]NoDeviceConnected
[14:12:45 350][Global][Inf]--Host: Contrôleur d’hôte compatible xHCI USB
[14:12:45 350][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_8c31&subsys_06121028& rev_04#3&11583659&0&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[14:12:45 350][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&352e7820&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:12:45 351][Global][Inf]-------->[Port0]NoDeviceConnected
[14:12:45 356][Global][Inf]-------->[Port1]Other device
[14:12:45 356][Global][Inf]-------->[Port2]NoDeviceConnected
[14:12:45 358][Global][Inf]-------->[Port3]Other device
[14:12:45 358][Global][Inf]-------->[Port4]NoDeviceConnected
[14:12:45 358][Global][Inf]-------->[Port5]NoDeviceConnected
[14:12:45 358][Global][Inf]-------->[Port6]NoDeviceConnected
[14:12:45 358][Global][Inf]-------->[Port7]NoDeviceConnected
[14:12:45 359][Global][Inf]-------->[Port8]Other device
[14:12:45 359][Global][Inf]-------->[Port9]NoDeviceConnected
[14:12:45 359][Global][Err]-------->[Port10]Error connect status 3
[14:12:45 360][Global][Err]-------->[Port11]Error connect status 3
[14:12:45 360][Global][Err]-------->[Port12]Error connect status 3
[14:12:45 360][Global][Err]-------->[Port13]Error connect status 3
[14:12:45 360][Global][Err]-------->[Port14]Error connect status 3
[14:12:45 360][Global][Inf]-------->[Port15]NoDeviceConnected
[14:12:45 360][Global][Inf]-------->[Port16]NoDeviceConnected
[14:12:45 360][Global][Inf]--Scan USB host controller complete
[14:12:45 361][Global][Inf]--Update data center with HubMap
[14:12:45 361][Global][Inf]--Scan end
[14:12:46 879][Global][War]--Close tool
[14:12:47 434][Global][War]--Controler exit
[14:12:52 768][Global][Inf]--USB_Burning_Tool soft Version: V2.1.9.0
[14:12:52 768][Global][Inf]--Windows Version: Microsoft Windows 10, Bit: 64
[14:12:52 777][Global][Inf]--Scan usb device
[14:12:52 777][Global][Inf]--Aml scan WorldCup Device
[14:12:52 781][Global][Inf]--Host: Intel(R) 8/C220 USB EHCI N° 1 - 8C26
[14:12:52 781][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_8c26&subsys_06121028& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[14:12:52 782][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&353bfc3e&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:12:52 845][Global][Inf]-------->[Port0]USB#VID_8087&PID_8000#5&23606a80&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:12:52 845][Global][Inf]---------->[Port0]NoDeviceConnected
[14:12:52 845][Global][Inf]---------->[Port1]NoDeviceConnected
[14:12:52 845][Global][Inf]---------->[Port2]NoDeviceConnected
[14:12:52 845][Global][Inf]---------->[Port3]NoDeviceConnected
[14:12:52 845][Global][Inf]---------->[Port4]NoDeviceConnected
[14:12:52 845][Global][Inf]---------->[Port5]NoDeviceConnected
[14:12:52 845][Global][Inf]-------->[Port1]NoDeviceConnected
[14:12:52 846][Global][Inf]--Host: Intel(R) 8/C220 USB EHCI n° 2 - 8C2D
[14:12:52 846][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_8c2d&subsys_06121028& rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[14:12:52 846][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&12e72867&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:12:52 908][Global][Inf]-------->[Port0]USB#VID_8087&PID_8008#5&1ffa69d&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:12:52 908][Global][Inf]---------->[Port0]NoDeviceConnected
[14:12:52 908][Global][Inf]---------->[Port1]NoDeviceConnected
[14:12:52 908][Global][Inf]---------->[Port2]NoDeviceConnected
[14:12:52 908][Global][Inf]---------->[Port3]NoDeviceConnected
[14:12:52 908][Global][Inf]-------->[Port1]NoDeviceConnected
[14:12:52 910][Global][Inf]--Host: Contrôleur d’hôte compatible xHCI USB
[14:12:52 910][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_8c31&subsys_06121028& rev_04#3&11583659&0&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[14:12:52 910][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&352e7820&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:12:52 910][Global][Inf]-------->[Port0]NoDeviceConnected
[14:12:52 914][Global][Inf]-------->[Port1]Other device
[14:12:52 914][Global][Inf]-------->[Port2]NoDeviceConnected
[14:12:52 915][Global][Inf]-------->[Port3]Other device
[14:12:52 915][Global][Inf]-------->[Port4]NoDeviceConnected
[14:12:52 915][Global][Inf]-------->[Port5]NoDeviceConnected
[14:12:52 915][Global][Inf]-------->[Port6]NoDeviceConnected
[14:12:52 915][Global][Inf]-------->[Port7]NoDeviceConnected
[14:12:52 916][Global][Inf]-------->[Port8]Other device
[14:12:52 916][Global][Inf]-------->[Port9]NoDeviceConnected
[14:12:52 916][Global][Err]-------->[Port10]Error connect status 3
[14:12:52 916][Global][Err]-------->[Port11]Error connect status 3
[14:12:52 917][Global][Err]-------->[Port12]Error connect status 3
[14:12:52 917][Global][Err]-------->[Port13]Error connect status 3
[14:12:52 917][Global][Err]-------->[Port14]Error connect status 3
[14:12:52 917][Global][Inf]-------->[Port15]NoDeviceConnected
[14:12:52 917][Global][Inf]-------->[Port16]NoDeviceConnected
[14:12:52 917][Global][Inf]--Scan USB host controller complete
[14:12:52 917][Global][Inf]--Update data center with HubMap
[14:12:52 918][Global][Inf]--Scan end
[14:13:00 314][Global][Inf]--OpenImg C:\Users\GI\Desktop\M8S_PLUS_W 20180622.img
[14:13:04 325][Global][Inf]--check img crc success!
[14:13:04 325][Global][Err]--[14:13:04 326]Parse platform.conf
[14:13:04 330][Global][Inf]--Parsing burning package
[14:13:04 331][Global][Inf]--Load configuration file C:\Program Files (x86)\Amlogic\USB_Burning_Tool\temp
[14:13:04 331][Global][Inf]--Parse burning configuration file C:\Program Files (x86)\Amlogic\USB_Burning_Tool\temp\burn_config.xm l
[14:13:04 339][Global][Inf]--Get burning key
[14:13:14 915][Global][Inf]--Catch DBT_DEVICEARRIVAL
[14:13:14 915][Global][Inf]--Scan usb device
[14:13:14 915][Global][Inf]--Aml scan WorldCup Device
[14:13:14 916][Global][Inf]--Host: Intel(R) 8/C220 USB EHCI N° 1 - 8C26
[14:13:14 916][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_8c26&subsys_06121028& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[14:13:14 916][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&353bfc3e&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:13:14 978][Global][Inf]-------->[Port0]USB#VID_8087&PID_8000#5&23606a80&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:13:14 978][Global][Inf]---------->[Port0]NoDeviceConnected
[14:13:14 978][Global][Inf]---------->[Port1]NoDeviceConnected
[14:13:14 978][Global][Inf]---------->[Port2]NoDeviceConnected
[14:13:14 978][Global][Inf]---------->[Port3]NoDeviceConnected
[14:13:14 978][Global][Inf]---------->[Port4]NoDeviceConnected
[14:13:14 978][Global][Inf]---------->[Port5]NoDeviceConnected
[14:13:14 978][Global][Inf]-------->[Port1]NoDeviceConnected
[14:13:14 978][Global][Inf]--Host: Intel(R) 8/C220 USB EHCI n° 2 - 8C2D
[14:13:14 978][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_8c2d&subsys_06121028& rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[14:13:14 978][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&12e72867&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:13:15 042][Global][Inf]-------->[Port0]USB#VID_8087&PID_8008#5&1ffa69d&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:13:15 042][Global][Inf]---------->[Port0]NoDeviceConnected
[14:13:15 042][Global][Inf]---------->[Port1]NoDeviceConnected
[14:13:15 042][Global][Inf]---------->[Port2]NoDeviceConnected
[14:13:15 042][Global][Inf]---------->[Port3]NoDeviceConnected
[14:13:15 042][Global][Inf]-------->[Port1]NoDeviceConnected
[14:13:15 043][Global][Inf]--Host: Contrôleur d’hôte compatible xHCI USB
[14:13:15 043][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_8c31&subsys_06121028& rev_04#3&11583659&0&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[14:13:15 043][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&352e7820&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:13:15 043][Global][Inf]-------->[Port0]NoDeviceConnected
[14:13:15 043][Global][Inf]-------->[Port1]Other device
[14:13:15 043][Global][Inf]-------->[Port2]NoDeviceConnected
[14:13:15 044][Global][Inf]-------->[Port3]Other device
[14:13:15 044][Global][Inf]-------->[Port4]NoDeviceConnected
[14:13:15 044][Global][Inf]-------->[Port5]NoDeviceConnected
[14:13:15 044][Global][Inf]-------->[Port6]NoDeviceConnected
[14:13:15 044][Global][Inf]-------->[Port7]NoDeviceConnected
[14:13:15 045][Global][Inf]-------->[Port8]Other device
[14:13:15 045][Global][Inf]-------->[Port9]\\?\usb#vid_1b8e&pid_c003#5&25587c9f&0&10#{a5dcbf1 0-6530-11d2-901f-00c04fb951ed}
[14:13:15 045][Global][Err]-------->[Port10]Error connect status 3
[14:13:15 045][Global][Err]-------->[Port11]Error connect status 3
[14:13:15 045][Global][Err]-------->[Port12]Error connect status 3
[14:13:15 045][Global][Err]-------->[Port13]Error connect status 3
[14:13:15 046][Global][Err]-------->[Port14]Error connect status 3
[14:13:15 046][Global][Inf]-------->[Port15]NoDeviceConnected
[14:13:15 046][Global][Inf]-------->[Port16]NoDeviceConnected
[14:13:15 046][Global][Inf]--Scan USB host controller complete
[14:13:15 046][Global][Inf]--Update data center with HubMap
[14:13:15 046][Global][Inf]--Insert new hub5
[14:13:15 046][Global][Inf]--Update hub5 device data
[14:13:15 046][Global][Inf]--Update HUB5-1
[14:13:15 046][HUB5-1][Inf]--Update device path
[14:13:15 046][Global][Inf]--Update HUB5-2
[14:13:15 046][HUB5-2][Inf]--Update device path
[14:13:15 046][Global][Inf]--Update HUB5-3
[14:13:15 046][HUB5-3][Inf]--Update device path
[14:13:15 046][Global][Inf]--Update HUB5-4
[14:13:15 046][HUB5-4][Inf]--Update device path
[14:13:15 046][Global][Inf]--Update HUB5-5
[14:13:15 046][HUB5-5][Inf]--Update device path
[14:13:15 046][Global][Inf]--Update HUB5-6
[14:13:15 046][HUB5-6][Inf]--Update device path
[14:13:15 046][Global][Inf]--Update HUB5-7
[14:13:15 046][HUB5-7][Inf]--Update device path
[14:13:15 046][Global][Inf]--Update HUB5-8
[14:13:15 046][HUB5-8][Inf]--Update device path
[14:13:15 046][Global][Inf]--Update HUB5-9
[14:13:15 046][HUB5-9][Inf]--Update device path
[14:13:15 046][Global][Inf]--Update HUB5-10 \\?\usb#vid_1b8e&pid_c003#5&25587c9f&0&10#{a5dcbf1 0-6530-11d2-901f-00c04fb951ed}
[14:13:15 046][HUB5-10][Inf]--Update device path
[14:13:15 047][Global][Inf]--Begin thread for HUB5-10
[14:13:15 047][Global][Inf]--Update HUB5-11
[14:13:15 047][Global][Inf]--Burning thread HUB5-10 start
[14:13:15 047][HUB5-11][Inf]--Update device path
[14:13:15 047][Global][Inf]--Update HUB5-12
[14:13:15 047][Global][Inf]--Burning thread HUB5-10 begin run
[14:13:15 047][HUB5-12][Inf]--Update device path
[14:13:15 047][Global][Inf]--Update HUB5-13
[14:13:15 047][HUB5-13][Inf]--Update device path
[14:13:15 047][Global][Inf]--Update HUB5-14
[14:13:15 047][HUB5-14][Inf]--Update device path
[14:13:15 047][Global][Inf]--Update HUB5-15
[14:13:15 047][HUB5-15][Inf]--Update device path
[14:13:15 047][Global][Inf]--Update HUB5-16
[14:13:15 047][HUB5-16][Inf]--Update device path
[14:13:15 047][Global][Inf]--Update HUB5-17
[14:13:15 047][HUB5-17][Inf]--Update device path
[14:13:15 047][Global][Inf]--Add Hub5: \\.\USB#ROOT_HUB30#4&352e7820&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} to m_HubDeviceDataVector
[14:13:15 047][Global][Inf]--Scan end
[14:13:18 662][Global][Inf]--User click start button
[14:13:18 664][Global][Inf]--SetErase
[14:13:18 664][Global][Inf]--Enable burning 1
[14:13:18 664][Global][Inf]--Scan usb device
[14:13:18 664][Global][Inf]--Aml scan WorldCup Device
[14:13:18 665][Global][Inf]--Host: Intel(R) 8/C220 USB EHCI N° 1 - 8C26
[14:13:18 665][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_8c26&subsys_06121028& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[14:13:18 665][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&353bfc3e&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:13:18 717][HUB5-10][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&25587c9f&0&10#{a5dcbf1 0-6530-11d2-901f-00c04fb951ed} 0x000003b4
[14:13:18 727][Global][Inf]-------->[Port0]USB#VID_8087&PID_8000#5&23606a80&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:13:18 727][Global][Inf]---------->[Port0]NoDeviceConnected
[14:13:18 727][Global][Inf]---------->[Port1]NoDeviceConnected
[14:13:18 727][Global][Inf]---------->[Port2]NoDeviceConnected
[14:13:18 727][Global][Inf]---------->[Port3]NoDeviceConnected
[14:13:18 727][Global][Inf]---------->[Port4]NoDeviceConnected
[14:13:18 727][Global][Inf]---------->[Port5]NoDeviceConnected
[14:13:18 727][Global][Inf]-------->[Port1]NoDeviceConnected
[14:13:18 729][Global][Inf]--Host: Intel(R) 8/C220 USB EHCI n° 2 - 8C2D
[14:13:18 729][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_8c2d&subsys_06121028& rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[14:13:18 730][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&12e72867&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:13:18 780][HUB5-10][Inf]--CloneImageProxy
[14:13:18 780][Global][Inf]--OpenImg C:\Users\GI\Desktop\M8S_PLUS_W 20180622.img
[14:13:18 781][Global][Err]--[14:13:18 781][HUB5-10][Inf]--Connect path=Contrôleur d’hôte compatible xHCI USB/P0/P9
[14:13:18 781][HUB5-10][Inf]--Start burning...
[14:13:18 791][Global][Inf]-------->[Port0]USB#VID_8087&PID_8008#5&1ffa69d&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:13:18 791][Global][Inf]---------->[Port0]NoDeviceConnected
[14:13:18 791][Global][Inf]---------->[Port1]NoDeviceConnected
[14:13:18 791][Global][Inf]---------->[Port2]NoDeviceConnected
[14:13:18 791][Global][Inf]---------->[Port3]NoDeviceConnected
[14:13:18 791][Global][Inf]-------->[Port1]NoDeviceConnected
[14:13:18 793][Global][Inf]--Host: Contrôleur d’hôte compatible xHCI USB
[14:13:18 793][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_8c31&subsys_06121028& rev_04#3&11583659&0&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[14:13:18 794][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&352e7820&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:13:18 794][Global][Inf]-------->[Port0]NoDeviceConnected
[14:13:18 795][Global][Inf]-------->[Port1]Other device
[14:13:18 795][Global][Inf]-------->[Port2]NoDeviceConnected
[14:13:18 796][Global][Inf]-------->[Port3]Other device
[14:13:18 796][Global][Inf]-------->[Port4]NoDeviceConnected
[14:13:18 796][Global][Inf]-------->[Port5]NoDeviceConnected
[14:13:18 796][Global][Inf]-------->[Port6]NoDeviceConnected
[14:13:18 796][Global][Inf]-------->[Port7]NoDeviceConnected
[14:13:18 797][Global][Inf]-------->[Port8]Other device
[14:13:18 798][Global][Inf]-------->[Port9]\\?\usb#vid_1b8e&pid_c003#5&25587c9f&0&10#{a5dcbf1 0-6530-11d2-901f-00c04fb951ed}
[14:13:18 799][Global][Err]-------->[Port10]Error connect status 3
[14:13:18 799][Global][Err]-------->[Port11]Error connect status 3
[14:13:18 799][Global][Err]-------->[Port12]Error connect status 3
[14:13:18 799][Global][Err]-------->[Port13]Error connect status 3
[14:13:18 799][Global][Err]-------->[Port14]Error connect status 3
[14:13:18 799][Global][Inf]-------->[Port15]NoDeviceConnected
[14:13:18 799][Global][Inf]-------->[Port16]NoDeviceConnected
[14:13:18 799][Global][Inf]--Scan USB host controller complete
[14:13:18 800][Global][Inf]--Update data center with HubMap
[14:13:18 800][Global][Inf]--Update hub5 device data
[14:13:18 800][Global][Inf]--Update HUB5-1
[14:13:18 800][HUB5-1][Inf]--Update device path
[14:13:18 800][Global][Inf]--Update HUB5-2
[14:13:18 800][HUB5-2][Inf]--Update device path
[14:13:18 800][Global][Inf]--Update HUB5-3
[14:13:18 800][HUB5-3][Inf]--Update device path
[14:13:18 800][Global][Inf]--Update HUB5-4
[14:13:18 800][HUB5-4][Inf]--Update device path
[14:13:18 800][Global][Inf]--Update HUB5-5
[14:13:18 800][HUB5-5][Inf]--Update device path
[14:13:18 800][Global][Inf]--Update HUB5-6
[14:13:18 800][HUB5-6][Inf]--Update device path
[14:13:18 800][Global][Inf]--Update HUB5-7
[14:13:18 801][HUB5-7][Inf]--Update device path
[14:13:18 801][Global][Inf]--Update HUB5-8
[14:13:18 801][HUB5-8][Inf]--Update device path
[14:13:18 801][Global][Inf]--Update HUB5-9
[14:13:18 801][HUB5-9][Inf]--Update device path
[14:13:18 801][Global][Inf]--Update HUB5-10 \\?\usb#vid_1b8e&pid_c003#5&25587c9f&0&10#{a5dcbf1 0-6530-11d2-901f-00c04fb951ed}
[14:13:18 801][HUB5-10][Inf]--Update device path
[14:13:18 801][Global][Inf]--Update HUB5-11
[14:13:18 801][HUB5-11][Inf]--Update device path
[14:13:18 801][Global][Inf]--Update HUB5-12
[14:13:18 801][HUB5-12][Inf]--Update device path
[14:13:18 801][Global][Inf]--Update HUB5-13
[14:13:18 801][HUB5-13][Inf]--Update device path
[14:13:18 801][Global][Inf]--Update HUB5-14
[14:13:18 801][HUB5-14][Inf]--Update device path
[14:13:18 801][Global][Inf]--Update HUB5-15
[14:13:18 801][HUB5-15][Inf]--Update device path
[14:13:18 801][Global][Inf]--Update HUB5-16
[14:13:18 801][HUB5-16][Inf]--Update device path
[14:13:18 801][Global][Inf]--Update HUB5-17
[14:13:18 801][HUB5-17][Inf]--Update device path
[14:13:18 801][Global][Inf]--Scan end
[14:13:18 842][HUB5-10][Inf]--------------ERASE BOOTLOADER------------
[14:13:18 952][HUB5-10][Inf]--start SendIdentifyCmd
[14:13:18 952][HUB5-10][Inf]--2-4-0-0
[14:13:18 952][HUB5-10][Inf]-------------Download DDR.USB-----------
[14:13:18 952][HUB5-10][Inf]--Close device handle 0x000003b4
[14:13:19 015][HUB5-10][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&25587c9f&0&10#{a5dcbf1 0-6530-11d2-901f-00c04fb951ed} 0x000003b4
[14:13:19 078][HUB5-10][Inf]--2-4-0-0
[14:13:19 078][HUB5-10][Inf]--Control write pll reg1 0xd9000000:0x000000b1
[14:13:19 588][HUB5-10][Inf]--Control write pll reg1 0xd9000000:0x00005183
[14:13:20 097][HUB5-10][Inf]--Control write pll reg1 0xd9000000:0x000000b1
[14:13:20 608][HUB5-10][Inf]--Control write pll reg1 0xd9000000:0x00005183
[14:13:21 120][HUB5-10][Inf]--Write initial succeed
[14:13:21 120][HUB5-10][Inf]--Upload encrypt at 0xc8100228
[14:13:21 120][HUB5-10][Inf]--ulValue = 0xadfc318c
[14:13:21 120][HUB5-10][Inf]--Read encrypt value succeed
[14:13:21 120][HUB5-10][Inf]--Download DDR.USB,size: 49152!
[14:13:21 130][HUB5-10][Inf]--Transfer complete 49152
[14:13:21 131][HUB5-10][Inf]--Run at address 0xd9000000
[14:13:21 132][HUB5-10][Inf]--RunInRam success
[14:13:21 326][HUB5-10][Inf]--IOCTL_IDENTIFY_HOST_Handler ret=-5 error_msg=libusb0-dll:err [control_msg] sending control message failed, win error: Un périphérique attaché au système ne fonctionne pas correctement.
[14:13:21 355][Global][Inf]--Catch DBT_DEVICEREMOVECOMPLETE
[14:13:21 356][Global][Inf]--Scan usb device
[14:13:21 356][Global][Inf]--Aml scan WorldCup Device
[14:13:21 359][Global][Inf]--Host: Intel(R) 8/C220 USB EHCI N° 1 - 8C26
[14:13:21 359][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_8c26&subsys_06121028& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[14:13:21 359][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&353bfc3e&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:13:21 368][HUB5-10][Err]--[0x10105004]Romcode/Initialize DDR/Read initialize status/Error result
[14:13:21 368][HUB5-10][Inf]--Close device handle 0x000003b4
[14:13:21 423][Global][Inf]-------->[Port0]USB#VID_8087&PID_8000#5&23606a80&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:13:21 423][Global][Inf]---------->[Port0]NoDeviceConnected
[14:13:21 423][Global][Inf]---------->[Port1]NoDeviceConnected
[14:13:21 423][Global][Inf]---------->[Port2]NoDeviceConnected
[14:13:21 423][Global][Inf]---------->[Port3]NoDeviceConnected
[14:13:21 423][Global][Inf]---------->[Port4]NoDeviceConnected
[14:13:21 423][Global][Inf]---------->[Port5]NoDeviceConnected
[14:13:21 423][Global][Inf]-------->[Port1]NoDeviceConnected
[14:13:21 423][Global][Inf]--Host: Intel(R) 8/C220 USB EHCI n° 2 - 8C2D
[14:13:21 423][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_8c2d&subsys_06121028& rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[14:13:21 423][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&12e72867&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:13:21 485][Global][Inf]-------->[Port0]USB#VID_8087&PID_8008#5&1ffa69d&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:13:21 485][Global][Inf]---------->[Port0]NoDeviceConnected
[14:13:21 485][Global][Inf]---------->[Port1]NoDeviceConnected
[14:13:21 485][Global][Inf]---------->[Port2]NoDeviceConnected
[14:13:21 485][Global][Inf]---------->[Port3]NoDeviceConnected
[14:13:21 485][Global][Inf]-------->[Port1]NoDeviceConnected
[14:13:21 486][Global][Inf]--Host: Contrôleur d’hôte compatible xHCI USB
[14:13:21 486][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_8c31&subsys_06121028& rev_04#3&11583659&0&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[14:13:21 486][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&352e7820&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[14:13:21 486][Global][Inf]-------->[Port0]NoDeviceConnected
[14:13:21 486][Global][Inf]-------->[Port1]Other device
[14:13:21 486][Global][Inf]-------->[Port2]NoDeviceConnected
[14:13:21 487][Global][Inf]-------->[Port3]Other device
[14:13:21 487][Global][Inf]-------->[Port4]NoDeviceConnected
[14:13:21 487][Global][Inf]-------->[Port5]NoDeviceConnected
[14:13:21 487][Global][Inf]-------->[Port6]NoDeviceConnected
[14:13:21 487][Global][Inf]-------->[Port7]NoDeviceConnected
Hello, I have a M8S Pro W rev2.3 and I think that I have bricked it. I tried to install M8S_PRO_W-ota-20180312.181951.V0213 from usb, it was installed (i think) the box did a shut down and since then it's stuck with red led. I have tried to reset it with the two pins, I have tried also to install several .img but none working: in USB burning tool it's stuck at Uboot error. Any ideas?! Thanks!!
LE: I did it!! I have used the rom's from here.
At the end I bricked the M8S PRO @ completely. The only thing that works is USB Burning tool, but I cannot find a suitable firmware to bring the unit back to life. The update process hangs at 4% with [0x10303004]Romcode/Switch status/Identify/Error result This is the uart output BL2 Built : 19:04:28, May 29 2018. \ngxl
There are currently 1271 users online. 1 members and 1270 guests.
