It's a frankenfirmware, so there is not a clear base, i adapted it to X96 Max and GT1 Mini devices but it shoud run on many other device based on U211 motherboard so S905X2.
Probably if it's not clearly meant for your device you'll have to change the remote config file in vendor/etc., and you'll get some lack on functionality on led or accessory devices, you have just to test it, but be careful:
WARNING:
I'm not responsible and nor the forum that hosts my ROM is, of any damage or malfunction caused on your device, during the flash or the use of my ROM.
You'll take the responsibility of what you do.
My Roms cannot brick your device, but you can flashing it improperly. I'm not a chinese box help center i hope you'll understand what i mean
Apks included:
- Opengapps Atv
- App Drawer from LineageOs
- Totalcommander
- Magiskmanager
- Aptoide ATV
- Netflix
- Kodi
- VLC
- AmazonPrime Video for atv though it doesn't work on level 3 devices
Known Bugs:
- let me know
This is not a real bug but a lack of these low cost devices:
Amazon Prime doesn't start cause lacking of Level 1 Widevine certification.
Flash it with Amlogic Usb Burning Tools 2.1.6.8: load the fw, then, after the file check is completed click start, plug the usb male to male cable in the blu usb (3.0) and wait for completion.
XTMOD Android TV 4 Changelog:
- Updated many Android Tv apps;
- Updated Magisk root; (reboot once to activate it)
- Standard Topbar and Navbar are present but not visible swipe up swipe down (some users asked me for that);
- as the previous version double click on home button brings up recent app;
- Fixed some wrong fix
- Fixed Ethernet Bug on X96 Max 3/4 Gb the 2gb has no bug;
- Probably fixed S-Pdif Bug;
- Many things i forgot to note in the process.
- it's pratically a whole new release, so some new bug it's possible
Download Links:
NOTE:
If you would like to report bug, issue ot whatever, write clearly which device and do not ask for things that are not included in actual Amlogic sources, i can do something but i cannot create gold without lead
Enjoy!
