[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
Originally posted by kenduvernay View Post
I'd like to change the Launcher, how to?
This one is based on Android Tv system and it's the launcher the main part of it.
Originally posted by Xannytech View Post
Ok, so you're using the wrong firmware, it's better for your use to flash the standard 8.1 firmware: https://forum.freaktab.com/forum/tv-...-fixes-and-mod
Rom installed first time with a fresh install of Windows 7 on different laptop. Seems to work perfectly though I only use it to watch video via external USB HDD's. One problem and I think it is an Android problem, it only finds 2 of my 4 external HDD's. The stock image had the same problem. I don't think I will ever get that fixed.
Youtube works at 720p HD whereas stock is SD only. That's a nice change.
Total Commander reports an error stating that "Documents app" is missing so cannot explore further into my HDD problems.
Unless I can install OpenElec or LibreElec.
Installed on X96 Max 4/64
Looking like I am going back to stock in the hope 'they may' release a firmware update that solves my problem.Last edited by Charlie_Boy; 31 January 2019, 14:40.
Originally posted by Charlie_Boy View PostTotal Commander reports an error stating that "Documents app" is missing so cannot explore further into my HDD problems.
your HDDs problem it's due the restricted android policy, libreelec or openelec will not have this kind of issue because it's a linux distro.
Originally posted by Xannytech View Posthave you granted su permissions? Normally this error happen because you're trying to explore an "android protected" zone.
Total Commander has SU permissions but gives error about missing Document apk. Kodi has not asked SU for permission but sees only 2 HDD's.
About your supplemental HDDs i can't do nothing for now, it's a oreo security "issue", probably it's more than a stupid thing like mounting points, anyway you can help me to get where the problem is if connecting the hdds you can give me a logcat.
can you explain how to reporduce the error Total Commander gives?
About your supplemental HDDs i can't do nothing for now, it's a oreo security "issue", probably it's more than a stupid thing like mounting points, anyway you can help me to get where the problem is if connecting the hdds you can give me a logcat.Last edited by Charlie_Boy; 31 January 2019, 17:43.
I am trying to install a decent screen capture apk but not having much luck. Where is logcat found?
For a screenshot this is a good apk
And for a logcat try this
https://play.google.com/store/apps/d...bi5sb2djYXQiXQ..Please consider making a Donation to freakTab
Originally posted by blinkone View Post
Hi there.
adb connect your.ip.num.ber then on click ok on requester on tv screen, then adb logcat > logcat.txt
anyway nothing particularly wrong in logcat, so it's not a real issue.
About total commander dunno, i can put back documentsUi in next release no problem.
There are currently 2393 users online. 2 members and 2391 guests.
