[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
Originally posted by romanzp3 View PostI am can not edit file preinstall. sh(I am write command wake_lock) -error save
Originally posted by romanzp3 View PostHi Xannytech. I am can not edit file preinstall. sh(I am write command wake_lock) -error save
Originally posted by Chosenv1 View PostII also ran into this, but I thought that this is a feature of the totalcommander with the /system partition. I found a temporary solution. Remember what rights are exposed to this file (most likely rwx-r-r), then try to copy this file to homedir and remove file from original location.Make the necessary changes in the file, which is located in the home folder, and then copy it back to its original location. Do not forget to return the rights to the file that were originally
Anyway all this discussion is not ROM related so it's O.T.
Hi, just flashed this today not used it for long but so far so good, it runs really well , I had issue with homescreen app draw reseting after restart but fixed following info you sent to another user here, Also I think the sleep is fixed with stock if set to sleep it would auto power on again but havent tested it for long to be sure , Once i used it for longer will report back
One thing i noticed is that no option to start screensaver ? or set box to sleep if no activity
Thanks for all the hard work you put into these its very much Appreciated and have sent Donation which you really deserve
Thanks Again
Originally posted by uscool View PostHi, just flashed this today not used it for long but so far so good, it runs really well , I had issue with homescreen app draw reseting after restart but fixed following info you sent to another user here, Also I think the sleep is fixed with stock if set to sleep it would auto power on again but havent tested it for long to be sure , Once i used it for longer will report back
Thanks Again
If i cannot solve for the new version, i'll found a way to preset the screensaver that is active by default anyway
Originally posted by Xannytech View Post
thanks a lot for your support and the report, i prepared a new version, just waiting for a new setting app to add the screen saver, because i used such slot for droidsetting in this version.
Hi, just update after using for 1 day only issues I came across once you put the box on standby/sleep doesn't happen right away but after sometime the box won't come out of standby have to take out the power, so now I just set the power to shutdown when power is pressed
Can you add setting for box to shutdown instead of sleep if no activity ? Having it set to sleep would just give issue if sleep isn't fixed
I noticed the offical YouTube tv some videoes are scrambled in green with sound playing is this codec issue
other then that it's been running very well and stable
thanks
Originally posted by uscool View PostHi, just update after using for 1 day only issues I came across once you put the box on standby/sleep doesn't happen right away but after sometime the box won't come out of standby have to take out the power, so now I just set the power to shutdown when power is pressed
thanksabout yt dunno, i'll check the logcat. thanks for your report.
more report like this from more users will help me to improva a lot the firmware.
Hi, after using it for longer now , I have attached screenshot of YouTube TV app usually happens on live channels streaming, Smart YouTube App works fine, Also noticed the front display time is sometimes wrong and 1hr ahead but the time in the box is correct
another issue i came across is when using WiFi with VPN I have used PIA and NordVPN the speeds are great , after some time usually watching YouTube its the only main thing i been using not sure if will happen using something else the WIFI will just vanish looking in WIFI settings it doesnt find any WIFI like its dead and box slows down pulling the power out will solve it till the next time
WIFI works fine when not using VPN also no issues with VPN enabled if using Ethernet
just wondering what box is this ROM based on ?
these are not big issues so can work around them and still much better using ATV then stock x96 max rom
Kind Regards
Originally posted by uscool View PostHi, after using it for longer now , I have attached screenshot of YouTube TV app usually happens on live channels streaming, Smart YouTube App works fine, Also noticed the front display time is sometimes wrong and 1hr ahead but the time in the box is correct
Kind Regards
There are currently 2417 users online. 2 members and 2415 guests.
