[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
Originally posted by tithitoy View PostPlease help!
My PC not detect X96 max
I flash XTMOD firmware by following these steps:
1.Open USB_Burning_Tool 2.1.6.8
2. Load XTMOD firmware and auto check.
3.Click Start button
4. Plug USB Male to Male cable to USB 3.0 port of box
5. Plug power
Nothing happen.
PS: With same computer and USB cable and USB_Burning_Tool I can flash other boxs like: TX3 mini, Minix X8h Plus.
Thanks for reading!
Change PC USB
Plug in the charger is not necessary
Originally posted by b0b33140 View Post
It works !? I do not understand what OP ROM means and you tried on which application?
I didn't try in any application, I just plugged and I could control home screen with joystick, is that not enough test?
Originally posted by zoelechat View Post
OP means Original Poster, so the ROM (=firmware!) from topic we're in
I do not understand, I tried with xbox usb and wireless controllers and nothing works. I have a box GT1 MINI and I tried the 3 roms Android TV of this forum. The 4 led flashes in the center of the controller and I am on the main screen under kodi or retroarch, nothing reacts.
Originally posted by BackinBlack View PostHi,i have successfully instaled x96 atv software to km9,but there is problem with lan,can you add drivers for 100mb lan amlogic..i will test your software after!
Things that not working:
Lan,wifi,bluetooth,remote....
Thx...
Originally posted by Xannytech View Post
hmm mine works as well on X96 or Gt1 Mini that's the firmware that has these drivers built in, so it's odd.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 2311 users online. 1 members and 2310 guests.
