[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
Hello, thanks for the greatest ROM!
I'm using x96max 4/64 with LG 2018 TV. And I have 2 problems related to the CEC power control.
I have another CEC device connected to the TV. To mention, I don't have such problems with X92 box (s912, atvXperience fw) with the same TV and the same another device. Without that device, all seems to work fine. When it's connected most of the time all is OK too. But sometimes after switching TV on by it's remote control power button:
1) X96 also wakes up as it should, but loses ethernet connection (to be strict - doesn't get an IP address). Switching off/on by CEC doesn't help. Unplugging/plugging LAN cable doesn't help. Reboot helps. This command also helps:
Code:su -c "ip link set down dev eth0; ip link set up dev eth0"
2) rarely, X96 doesn't wake up at all, doesn't react on IR. Only unplugging power cable helps. I haven't got this without ethernet (only wifi) - but that may be because it's rarity.
I've made at least 100 CEC power cycles (controlled by TV's remote), and got at least 10 LAN IP address losses, and at least 3 box hangs.
One observation - with another CEC device, LG TV makes 3 red blinks when switching on (seems to be some kind of CEC states syncing between TV and 2 boxes).
Does anybody has any thoughts about this?
Besides that i have some other nasty bugs, like the PBS Kids Video app closing itself instantly after launch (the regular PBS (non kids) video app works though), the BBC i player addon for kodi doesnt work either, both apps/addons do work on my mibox but not on my x96 4gb with XTMOD.
I have some more issues that i am happy to provide logs for but the most annoying issue so far is that the box doesnt support 10bit color depth in 2160p@60hz because for everything else i can rely on my other box or apps directly installed on my tv, but the x96 is supposed to run my uncompressed 4k movies :XLast edited by boxz0rd; 12 March 2019, 14:54.
Originally posted by imzsha View PostHey I installed this rom on t95q and all is working fine but I want to use android remote app which detects the tv box but doesn't connect I tried not be as well as gt mini roms but in both the resilt is same can any one point me what's wrong thanks
Originally posted by Atlas_co View Post
Works in my t95q,.. open air screen app first, you must link the application with the t95q
Can you tell what do you mean by link the application with t95q when I open air screen app it just says waiting for connection what steps should I take to make the Android remote work ?
Originally posted by imzsha View PostHey I managed to make Android remote app work but now I have another problem I have an app called thoptv sideloaded when I launch it says you have blocked ads whitelist in adblocker app to resume I don't see any adblocker app installed how do whitelist the app?
With the next commands we can restrict sleeping. But this makes CEC control unstable (at least for me with LG TV).
Code:su echo nosleep > /sys/power/wake_lock
There are currently 1383 users online. 0 members and 1383 guests.
