[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
    hello ,
    ?a ne marche pas chez moi
    ?a bloque ? 3% avec burning tool
    my tv box X96 max 4go
    comment savoir si c'est une U211 devices ?
    does not work at home
    blocked? 3% with burning tool
    how to know if it's a U211 devices?"
    i'm sorry i'm not speak english
    help me
    thanks
    Last edited by RISCy Dude; 13 April 2019, 03:49. Reason: Added English translation. Translation by Google. Please post in English for quickest response.
        hello ,
        help me
        thanks
          Originally posted by david57 View Post
          hello ,
          help me
          thanks
          Votre box a u211 carte mere, vous po7vez installer cette rom sans probleme.
          Vous devez utiliser usb burning tool version au moins 2.6.8, cest pourquoi ca arrete a 3%. Changez votre porte usb sur votre ordinateur si ca arrete plus de 3 %.
            merci
            metabesk
            thank you
            it works well
            (I changed usb ,port, usb cable burning tool 2.7.0,)
              merci
              metabesk
              thank you
              it works well
              Je vous en prie David
                Hi there,
                That looks extremly interessting ...
                I just received my x96 max and out of the box I am extremly unhappy with the UI and I cannot even make Bluetooth to work.
                What is the latest image ? The one listed in the first post?
                If so I will test it as soon as I figured out how to install it using Flash it with Amlogic Usb Burning Tools 2.1.6.8. :-D
                Thanks for your amazing work!
                  Anyone tried this on an H96 Max X2?
                    Bug: Led screen's time is one hour earlier than box's time.
                      Originally posted by Xannytech View Post
                      Known Bugs:
                      - let me know
                      Thanks for your awesome ROM!
                      Can some one help me, I have a issue with sleep mode.
                      My box X96 Max 4/64 can't return from sleep mode. After about 10 min in sleep it completely hangs. Don't respond on any key on the remote, and hdmi-cec also cant wake him up. Only power reset helps.
                      And one more question: How to disable the forced closure of any application with 4 clicks on the right mouse button. Because it is very annoying when playing through the moonlight with mouse.
                      Thanks in advance!
                        Hello.
                        the cec HDMI wake the box in power off , or just in sleep mode?
                          Thanks in advance!
                          The box has issue for normal standby its best to set it to shut down with power button this way you can turn it back on by remote
                            Xannytech
                            Will there be a new version X96 Max 4/32 & 4/64 V 4
                              Ok, thx!
                              What about 2nd question?
                                Hello.
