[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
Originally posted by metabesk View Post
So updating doesnt spoil root access? Right?
Got v4 loaded up on my gt1-mini and everything runs smoothly!! Other then the fact I forgot androidtv doesn't let you set live wallpapers lmao.
Oh and Xannytech how do I close the live channel picture in picture window?
Using an AndroidTV Nouget rom on my x96(s905x) had a different "recents" screen which gave the option.
This is the recents screen I'm talking about, it's available on the shield
Originally posted by huffmybrd View PostGot v4 loaded up on my gt1-mini and everything runs smoothly!! Other then the fact I forgot androidtv doesn't let you set live wallpapers lmao.
http://www.aftvnews.com/wp-content/u...t-app-page.jpgor bring up the navbar is hidden, comes up swiping up from bottom.
Originally posted by Xannytech View Post
have you tried double click home on your remote? The framework is setted like this, it's not so fancy as shield but it worksor bring up the navbar is hidden, comes up swiping up from bottom.
Double click home gets me into recents but its standard Android recents screen, not AndroidTV recents. There's no option to control the PiP via the current setup other then having to force close live channels, sorry i undestood correctly what you meant, but i should use the normal framework for a matter of compatibility with other part of the system.
As you probably know yet, these Android Tv Firmwares are compiled by us rom developers not using sources, but gathering programs, stuffs and adapting the standard android to work as Android TV, is very similar it's 90/100 like a real Android Tv but it's not really true.
The only solution in your case could come if an Amlogic device born with Android Tv uses a framework similar to Nvidia Shield, so i can get it and make it work for our little 30$ cinese boxes.
Originally posted by val1950 View PostI use with Tanix tx5 max. Clock not work. I use remote from T95Z Max - works 100%. This firmware is the best what I use on Tanix tx5 max.
1)tx5 max's remote which buttons doesnt work?
2)Since when you use tanix tx5 max?
3) Which version u use x96max 9r beelink?
There are currently 2280 users online. 0 members and 2280 guests.
