[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
Originally posted by zoelechat View PostI meant backup OF internal storage, just in case you've got some personal stuff there.
Sure, using that one from the beginning without any problem, I think I got it here on forum, possible I made flashable zip myself, don't remember...
twrp.u211-3.2.3-1-signed.zip
Should be included in firmware anyway, would at least save that step, and I really see no valuable reason to persist with original recovery (except laziness maybe)
ps: Beware SD card (="EXT") should be FAT formatted to be browsable from original recovery (yet another nice "advantage" of it)
By the way, i used the same version but this version couldnt find any partition to backup for me?
Originally posted by Xannytech View Post
Ehmi normally provide twrp in my fws, here i will not until a FULLY working release (so i should build it myself) is out, the normal user do not find problems but there are on partitions.
So it's up to the user same goes for AFR, that i found could cause problems on some old tv. I prefer to give you a fully flawess working fw, then you can mess with it...
So there isnt a way restore previous settings and apps each time you provide an update?
Originally posted by metabesk View Post
If i cant backup the internal storage, how can i backup data partition to restore after a fw upgrade?
Originally posted by metabesk View PostBy the way, i used the same version but this version couldnt find any partition to backup for me?
Originally posted by zoelechat View Post/data and internal storage are different partitions. /system, /vendor and so on are also not part of so-called "internal storage".
TWRP you mean? No idea
İ seem to remember that even i rebooted once and reboot to recovery, after that still no partitions, but heck you made me doubt myself
Ah by internal storage you mean tue partition that kernel firmware is installed? if so yes you are right.
Originally posted by metabesk View Postseem to remember that even i rebooted once and reboot to recovery, after that still no partitions, but heck you made me doubt myself
Bug: i tried at 2 different places so different internet providers, installing something from play store takes so mich time to start, it says download waiting and more than many minutes you have to wait and sometimes it takes forever.
With aptoide tv it is super fastLast edited by metabesk; 27 April 2019, 19:24.
Originally posted by metabesk View PostBug: i tried at 2 different places so different internet providers, installing something from play store takes so mich time to start, it says download waiting and more than many minutes you have to wait and sometimes it takes forever.
There are currently 4799 users online. 1 members and 4798 guests.
