[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
I installed the v4, I have a problem with the "sleep mode" the box will not turn off the first time.
A new version "AFRD 0.3.2" is available : https://www115.zippyshare.com/v/uKWfuOho/file.html
it's the 4PDA file, but the registration is difficult, so I share it here. but if you want to register on 4pda, go to 4pda on android apps (no captcha)
sorry for my english
source : https://4pda.ru/forum/index.php?showtopic=948250Last edited by dude75; 23 May 2019, 21:17.
Originally posted by castiso9 View PostHello i cant connect my x96 max usb to may pc to flash firwmare. I use port usb 3.0.
I connect pass 3 sec auto desconnect?
Sorry my ingles
Help
Enviado do meu LYA-L29 atrav?s do Tapatalk
: https://forum.xda-developers.com/and...tools-t3786991
I helped him to finisch his 6.0, but don't know if really works as it should.
Originally posted by castiso9 View PostHello my remote control not working. Help?
Any code to set to work in box?
My box work again tanks
anyway download and use ATV remote on your smartphone if you cannot solve.
Hello! Installed firmware on x96s tv stick version 2/16, works very well! But there is one problem - when the stick is off for about an hour or more it stops turning on, only the reset button helps. please advise what is the cause and how to fix it? What settings do I need to change? Thank you!
Originally posted by elena82 View PostHello! Installed firmware on x96s tv stick version 2/16, works very well! But there is one problem - when the stick is off for about an hour or more it stops turning on, only the reset button helps. please advise what is the cause and how to fix it? What settings do I need to change? Thank you!
not sure if you use WIFI but i had issue with WIFI randomly stop working can happen in 30mins or over 10hrs, box needs restarting to get WIFI to work again this is the 2/16 model
There are currently 4739 users online. 0 members and 4739 guests.
