[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
Originally posted by TheBlackening View PostI think it is possible to do it with amlogic tools 6.0.
But I'm not sure
Enviado do meu POCOPHONE F1 atrav?s do Tapatalk
Originally posted by JoeGamer View Post
The problem is, that the version 6.0 si crashing, version 5.5 was working, but got that Legacy error and version 4 is unpacking the img, but after like 10hours the header.bin file was like 24GB..
Hi guys,
How are you all?
I have a question if someone wants to help me :-). I have an X96 MAx 4/64 and i can't load a firmware anymore sinds i load the firmware from Xannytec "XTM_ATV_X96_4_4.img".
I get 2 kind of issues.
The first issue, i get it every time. Its a partition_aml_dtb issue it stops everytime there (see Picture as attachment).
The second issue come from the firmware made by Xannytec. The first time i load it, it was good, and works great. The box started and i tested the firmware. After that wanted to go back to the original firmware but it didn't work. I got the bootlogo loop issue. I tried to reload the firmware from Xannytec back again and now i get the vendor issue (see picture as attachment).
I really tried everything (bootmaker, burncard maker, twrp, recovery, wipe data, i tried also every kind of firmware on USB or SDCard, Shortcut, etc.) nothing works :-(
Does someone know this issue maybe? Or know how to deal with this issue?
That are the specs of my hardware:
X96 max 4/64
4+64+6356
ZF190326
Logicboard Q5X2 v5.5 19015
Thank you very much everyone for helping me :-)
You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
Originally posted by Prins_007 View PostHi guys,
How are you all?
X96 max 4/64
4+64+6356
ZF190326
I wouldn't do the "Erase all"
In some cases, somehow the box loses the wifi MAC address.
I would recommend doing the short NAND pin method.
I had a similar situation with a X96 Mini.
After installing the ROM from a W95, the only way I could install another ROM was through short NAND pin method.
I hope it helps
Cheers
I hope it helps
Cheers
Thank you for trying helping me :-) i appreciate.
Also tried today... The short nand or pin seems to do nothing specially. What i don't understand is why the only Rom who passed the aml_dtb is de XTM_ATV_4_4.img but with vendor issue. all other rom/firmware get stuck at aml_dtb....
I was wondering.. how long you waited at bootlogo before pulling the plug?
Sometimes it takes a longer time to move forward.
Originally posted by TheBlackening View PostIf you try to flash the original ROM, do you also always get the AML dtb error, or it flashes 100% but gets stuck at bootlogo?
Thank you for your help.
Always get the AML dtb issue. I don't know what the XTM_ATV_4_4.img did :-( It seems that the only firmware that get passed the AML issue is this firmware. All other firmwares get stuk. But the issue of the XTM_ATV_4_4.img firmware now is that one get stuk at Vendor check. 96%... and about the loop i waited sometimes 30min sometimes hours if i was busy, the box stays on.
There are currently 2062 users online. 1 members and 2061 guests.
