[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
Xannytech
I like Android 9, but there is a jamb with IPTV periodic reboot when watching IPTV The driver amvdec_h264mvc.ko is to blame for Android 9 in the Amlogic SDK.
Try the following: in the / vendor / lib / modules / folder, replace it with a file from the archive. File permissions - 644. Attached files amvdec.zip ( 104,65 КБ )
Xannytech
hmm interesting, give me a different link because the one you posted it's unreachable for me.
Xannytech The solution to the problem of the console PTV periodic reboot when watching in the 9th version of the android: Unzip, replace the files along the path / vendor / lib / modules / with the appropriate rights (rw-r-r), reboot the device. In fact, it is enough to replace only amvdec_h264mvc.ko, but just in case, I changed all the modules.
I downloaded the firmware , I’m getting a error when I burn at 3% rom code boot stage error not sure why this is happening as I’ve burned other roms in the past with no issues also using the new version of the burn tool 2.1.7 if anyone has any suggestions that would be greatly appreciated thanks in advance thank you for your work
