[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
Originally posted by janek View PostHi.
I have a x96 max. How I can unbrick this device? Probably this is new revision. Thanks
Create an SD card using burn card maker with the new ROM.
With reset wires connected and sd card inserted power on the box and it will boot up in update mode.
Keep hdmi connected to check progress and hopefully the update will apply.
That is how I recovered mine and I left the wires still soldered and ran them outside for future if needed.
Hope it helps.
Originally posted by Livio F View Post
New release USB Burning Tool 2.1.7.1? Can you post the link? Thanx
Has this ROM been tested to run well on Magicsee N5 Max s905x2 / 4/64GB / AP6255 WIFI / 1000G LAN?
- Does the remote fully work?
- Does the front-panel clock display work?
- Do you plan to have android 9 release for this ROM (this is what Magicsee sell now)?
ThanksLast edited by rafid; 19 October 2019, 09:27.
Originally posted by huffmybrd View PostDoes this have an adblocking host file included? If so where is it located? Because I need to edit it due to the fact I can not access trakt.tv VIA nova video player
Code:127.0.0.1 localhost ::1 ip6-localhost
There are currently 2056 users online. 2 members and 2054 guests.
