[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
Hi, great work here. I just got this on my X96 Max 4GB/32Gb. The Android 9 update seems good, but a couple things I have problems with.
1. HDR doesn't work right at least for me. Whenever I try to play hdr YouTube content it is pretty grey and not vivid like it should even with the sdr to hdr setting switched on. 4k SDR content seems just fine
2. I see no vulkan support, is there reasoning behind this?
For now, I've noticed two major bugs.
Bluetooth is not working.
I use plex in my box. If I connect through Wireless, it detects my server as being local, in my LAN. But if I connect through ethernet, It detects my server as being remote, on the internet. I've already tested with my computer connected to the same cable, and it detects Plex server as being in the local network, and streams with original quality. So I believe there is some bug on the Ethernet connection, something related to NAT or something like that, that when connected through Ethernet, won't detect local servers...
Many thanks for this ROM, it's miles better than the stock one.
Is there any MAC adress cloning, or routing, or something like that?
The WIFI MAC adress is completely different from the Ethernet adress, which is the same that is stamped on the android box. And in settings-about, the MAC adress that shows is not the one on the box, but the Wifi MAC...
Edit: Nevermind, t's the same with stock firmware...Last edited by MataRatos; 21 February 2020, 15:54.
I am having this issue with connecting X96 max 4/64 to my PC. The burning tool recognizes it, you hear the windows device plugged in sound and it says connection success, but after a few seconds it drops and you hear the unplugged device sound... preventing me to flash anything. I am using USB 3.0 port on the player.
I thought it was the because USB 2.0 cable, bought a new one 3.0 this time. Same result.
Any ideas?
Update: Fixed by pressing start button before plugging the device inLast edited by kulica; 24 February 2020, 14:56.
Originally posted by Xannytech View Post
lso XTM_X96M4G_ATV9_V1_0 here it is. It's for X96Max 4Gb based on V311P firmware so flash according with your device.
There are currently 2437 users online. 0 members and 2437 guests.
