(2) Do you have any idea how to install Magisk modules directly without Magisk root? Should I just mount /system to rw and set $MODDIR to be / ?
[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
I need to be able to delete files from external USB dives but this ROM doesn't work with Magisk so I cannot install module to allow deletion and Kodi won't allow deletion. Total Commander won't delete either. What are my options. Love this ROM by the way it is excellent but cannot delete files.
Once again fabulous work! Tested new update 9, on t95q 4/32, works great, few minor bugs but very nice.
minor bugs: no ethernet, after initial Google account setup cannot remove and then add different Google account without difficulties and functionality failing, such as assistant.
Is there anyway to add viper4android? I have tried, TWRP flashing, installing direct, with no luck, I usually use magisk module, so that being said any way to build this into firmware .IMG?
I have 2 same box (X96 Max 4/64) I'm buy first last year april, and second, few days ago. Im try upload (X96 Max 4/32 & 4/64 V 4.0) first X96 Max ok, no problem, new fw ready few min.
Working good.
New X96 max, (im buy this few days ago) im try upload same fw, and error error error.. im try 50 times...
USB Burning tool message: 3% ready and: [0x10401001]Romcode/Bl2_Boot stage Error
I'm try another android version and same message.. burning tool, sd method, twrp same....
Somebody know why?
thx
Originally posted by ecobit View PostI have 2 same box (X96 Max 4/64) I'm buy first last year april, and second, few days ago. Im try upload (X96 Max 4/32 & 4/64 V 4.0) first X96 Max ok, no problem, new fw ready few min.
Working good.
Somebody know why?
thx
There are currently 1936 users online. 0 members and 1936 guests.
