[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
Originally posted by Xannytech View Post
I am trying to burn firmware on my box but encountering this error in the log of burning tool.
HTML Code:[11:14:15 562]BL2 report Error, code= 32 [11:14:15 563][HUB3-5]cmd error, cmdType:43984 [11:14:15 563][HUB3-5]Aml_Libusb_bl2_boot2 end! [11:14:15 563][HUB3-5][Inf]--Release Semaphore [11:14:25 736][HUB3-5][Inf]--Detect Device remove timeout [11:14:25 736][HUB3-5][Inf]--Device is connected [11:14:25 736][HUB3-5][Inf]--Close device handle 0x00000930 [11:14:25 787][HUB3-5][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&1e7d8db7&0&5#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000930 [11:14:30 838] [HUB3-5][Inf]--0-0-1-8 [11:14:30 838][HUB3-5][Err]--CheckFileRunState failed [11:14:30 843][HUB3-5][Err]--[0x10303004]Romcode/Switch status/Identify/Error result [11:14:30 844][HUB3-5][Inf]--Close device handle 0x00000930
Originally posted by Prins_007 View Post
Oh i tried this one it give me the aml issue. I tried maybe 100 or more firmwares always the same :-( i hoop that the firmware that you are building will help.
do you loaded the firmare and then clicked start, and just then connected your device?
i don't think a different firmware could solve your problem, if any other solution like using amlogic 2.1.7.X or changing usb cable are excluded, i suggested you to reset the nand, shorting pins (it's pretty easy). if the device cannot completely flashed after nand reset, the only problem it's your pc/usb/cable/program.
Is the shortpin in the picture correct?
thank you :-)
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by sxcjb View PostX96 Max 4/64, please help me, the problem with the brush machine.
Thanks for reading
Originally posted by raruba View Post
Load the Rom then press the start button, hold reset on the box with pin...then plug in the USB to box (blue 3.0) cord that is plugged into your computer, then quickly plug in the power cord to the box also and wait for the beep beep, release reset button then...should load for you
You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Xannytech : may I ask which sources you took for your atv? Did you take existing atv system file? Or did you build all yourself?
I ask since I realized that obviously some people (me too :-p) take an existing system img (in my case it was the mecool atv9) and then bring it to boot. Doing so I experienced that the Mecool firmware asks for remote pairing on startup but I cant ship...
Originally posted by salehdeh76 View PostAnyone knows what is the error code “32” in BL2 and why this may happen? I tried several firmwares but no effect!
Anyone can help me to acquire a BL2.bin with config DDR3 792Mhz (Or DDR3L is also OK) After that I know how to build firmware for myself. But the hard stuff is that the source code of BL2 is not released by amlogic and I don't even know how to acquire proper binary versions of it?!
There are currently 1581 users online. 0 members and 1581 guests.
