[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
Hi Xannytech,
Welkom back, i hope that your father will be well and get soon better.
Dear friend can you maybe help me to solve my issue? I have a problem with the ATX firmware for the X96 max 4/64. Its now about 4 months ago the box is in a bootloop mod. I tried everything to get it back to normal but nothing works yet. If i try your firmware again it get stuck at vendor parts. 97-98% and if i try other firmwares it get stuck at 10% aml dtb. Do you know whats the problem hier? Thank you very much.You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
Originally posted by Xannytech View Post
Hi, i do not remember which device are you using, try with Amlogic tools 2.1.7.0, try to change usb cable, or port. But the good part is the bootloader it's working.
I really tried everything. Before ATX firmware there was no issue all things goes ok. But after ATX the first time all ok tried the firmware but after a few days get the bootloop it start but keep rebooting. Kan i also try the new firmware? I have also a X96 Max 4/64 maybe it will work?Last edited by Xannytech; 11 November 2019, 15:47.
you'll test the new fw when i'll release it (i hope you understand i need few days), anyway seems to me a usb problem or a memory problem, i got the very same device and i fLashed everything on it without any problem, eventually you tried to flash resetting the nand?
Flash resetting the nand is there any method that i can follow?
The issue is that the firmware stop at aml dtb check if its a firmware from other sites or stop at Vendor check if its from ATV. With usb cable or micro SD i get always the same issue.
so or you got a problem on your nand memory or try to reset it shourtcirtuing two pin and hope it will flash back a full firmware, got no more ideas.
you cannot root it thru magisk at now because of the system-on-root , so, just use the custom rom rooted yet with old methods.
Originally posted by Xannytech View PostI think you tried with power connected... during usb flashing.
There are currently 1283 users online. 0 members and 1283 guests.
