[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
A new version "AFRD 0.3.2" is available : https://www115.zippyshare.com/v/uKWfuOho/file.html
hello, could you share the afrd link? i can't download thanks
Originally posted by craser View PostA new version "AFRD 0.3.2" is available : https://www115.zippyshare.com/v/uKWfuOho/file.html
Hi All,
I have test this ROM V4 on X96 Max (2 Gb version, not support Bluetooth) with Tronsmart Mars G02 game pad (using 2.4 Ghz USB wireless) but it not working.
Can you tell me how to fixed this issue?
Thanks.
https://www.tronsmart.com/products/t...ame-controller
Xannytech
Good day Hello.
I think based on this firmware GT1_Mini_901N0_20190603.img will be much better to do Android 9.0 XTMOD-ATV X96 Max 4/32 V 5.0
https://drive.google.com/file/d/1BdP...JUalnp3nG/view
https://drive.google.com/file/d/1erXq_lPxlR2d6DKDH27YOoCHs6GiRAAe/viewLast edited by nikito7989; 07 June 2019, 07:58.
Originally posted by dude75 View PostI installed the v4, I have a problem with the "sleep mode" the box will not turn off the first time.
it's the 4PDA file, but the registration is difficult, so I share it here. but if you want to register on 4pda, go to 4pda on android apps (no captcha)
sorry for my english
source : https://4pda.ru/forum/index.php?showtopic=948250
Hi there,
First of all, thank you for your ROM. you litteraly saved my day lol.
I bought my first android box a few weeks, bought the GT1 mini. Very satisfying performance, but wack system and cannot use netflix or hbo and use the remote to navigate on them either....so went and bought the Xiaomi Mi Box S. Its fenomenal comparing to Beelink's.
Then Ive discovered that it lacks the DRM certification....even worse...but Im trying to manage to use it at some point, since the money is spent.... With your ROM, I can now use Netflix. Still can not navigate the app itself with the remote, because its not a TV app, but it works.
I was wondering if you can help with HBO running also.
At this point I dont mind buying another remote with integrated mouse to navigate properly, but since i managed to spend the money, i really would like to use it at is full potential.
Any way to install HBO like you did with Netflix? Ive tried all the apps on aptoid and play store.
Thank you!
EDIT: I Can Not also use Android TV RemoteLast edited by mariobombas; 27 June 2019, 15:54.
There are currently 3814 users online. 0 members and 3814 guests.
