[ROM] XTMOD-ATV X96 Max - GT1 and some U211 devices - S905X2 Android 8.1 [Android TV]
Originally posted by zoelechat View PostThen if replies here only have to be "your ROM is the best" with money attached, just tell itprobably it's better to not reply
Anyway mate i'm 50Yo, if i ask for donations is because i'd like to support more devices, and so i'll got a excuse with my wife to buy more, "My dear, you know my users asked me"
Originally posted by Xannytech View Post
Anyway mate i'm 50Yo, if i ask for donations is because i'd like to support more devices, and so i'll got a excuse with my wife to buy more, "My dear, you know my users asked me"). Let me explain current state of things if you don't mind:
-Out of the box, no h264@4k movie will play correctly (actually, say 10% tries hw decoding is triggered, randomly!)
-Faulty decoder looks to be amvdec_mh264 and getting rid of it (preventing module insertion) reliably fixes h264@4k up to 24/25fps by defaulting to amvdec_h264. Playback of 30fps remains crappy though (-> frame skipping).
-Your ROMs (only) are containing an amvdec_h264_4k2k module, sounds promising especially given issue, but unfortunately it's never used, in no case at all. What about it?
Better fix core issues before supporting more devices imho
Not that far to be that old either... Anyway, you missed the serious part of my post (because of age maybe?). Let me explain current state of things if you don't mind:
Anyway i don't mind to try to fix together things you know
My only problem it's my actual RL my father is very sick so sometimes i got no time to follow this thread or reply in PM nothing more. My personal amlogic 8.1 kitchen it's very efficent and fast to let me compile things in few minutes, so if we got the right idea no problem.
I'll try you know freetime permitting, but normally i need intensive testing and users like you can help me, now try to rename the module (the one promising but never used) giving to it the standard and used name module, probably nothing change but what we have to check is Vendor/etc/mediacodec settings maybe can help,
I also assume the "faulty" mh264 is there for a reason (seems to mean multi-h264), maybe used in some scenario I didn't try (multiple streams? PIP or I don't know...) therefore probably not a solution to just ignore it.
Already tried looots of stuff I don't remember all before reporting, and I thought you'd maybe have some more precise idea. Gotta dig more xml and so on (hoping it's not matter of buggy sourcecode or simply not capable hw!)
No problem I can test stuff if needed, when you want/can, not waiting after Amlogic to correctly play movies anyway, fortunately
Well, module filename doesn't matter (can call them 1 2 3.ko), it's just using what's available for source codec. Leaving "promising" 4k2k alone results in... software decoding! (where the 2 other modules left alone are doing at least "something", one correctly other not).
Code:<MediaCodec name="OMX.google.h264.decoder" type="video/avc" update="true"> <Limit name="measured-frame-rate-320x240" range="318-318" /> <Limit name="measured-frame-rate-720x480" range="115-115" /> <Limit name="measured-frame-rate-1280x720" range="43-43" /> <Limit name="measured-frame-rate-1920x1080" range="18-18" /> </MediaCodec>
Anyway what we cand do it's in the stuff i pointed to you, look for example in vendor/etc/media_codecs_performance.xml:
edit: well I tried a bunch of things (tweak "Limits" or even remove them all in both media_codecs.xml and media_codecs_performance, add a 3840*2160 line, with 1, 2 or 3 modules inserted combinations), it looks nothing has no effect at all! Results I had already got previously actuallyLast edited by zoelechat; 19 May 2019, 10:11.
There are currently 2174 users online. 2 members and 2172 guests.
