New ROM is 1.6a
1.6a fixes:
Fixes touch screen issues with real USB touch screens AND for APPs that need to emulate touches like Six Axis or Tinecore APP.
I replaced some lib files and added virtual_touchscreen.ko. The lib files were the key to fixing touch!
Bug:
Factory Data reset does not always work! At least on the V1 boards. I do not know if it does on the V3 boards. This bug exists in the stock ROM as well.
It works for me on my V1 board about 1 out of 5 times. This is some issue with the new kernel.
What I notice is if you leave the stick on for about 5 minutes then do a factory reset it seems to work. But it does not want to work right after a boot up. Very odd.
If your factory data reset does not work at all, simply fire up the flash tool and flash ONLY misc.img. On next boot it will do a factory erase.
Link has been updated below
_________________________________
Hey folks. So I finally finished the MK908 ROM.
I know some of you do not like the stock ROM that was released which this ROm is based off of.
But for me and my V1 board I love it. Best ROM yet from Tronsmart in my opinion.
Anyway I did try to fix some things for you V3 owners but probably not 100% to your liking.
Legitsu may have the answers to some things for the V3.
The odd thing about the stock ROM is the kernel is a 1080P kernel!
I found this out by editing build.prop
changing this to a 0
video.use.overlay=0
caused it to reboot at full 1080 and Antutu or other tools reported it as 1920x1080. With that set to a 1, Antutu reported it at 1280x720.
So I patched the kernel to a 720 kernel and got an increase in performance! Thus I give you my ROM with the 720 kernel and you can go back to 1080 kernel if you like.
Features and release notes for my 1.6 ROM:
1) Rooted and new SU and Superuser applied that supports Android 4.2.2
2) Stock ROM was only 2 Gig of APP space.
BUT you also have parameter file options!
There are also 1gb, 2gb, 4gb and 6gb options.
Read below for how to change that in the flash tool.
Realize if you use this 6gb option, internal SDcard will only have about 600 megs of free space!
3) Debloated of junk APPs and Google Apps you can get from Google Play.
I also updated Google Play and required Google APPs to the latest version.
4) As always, full init.d support! If you do not know what that is... ignore it. For geeks that want to use it. It is there!
5) I re-enabled location services. This is now in the settings menu.
Tested and working with all APPs that use it.
Remember to turn off GPS as we have no GPS.
6) I also re-enabled accessibility options in settings.
7) Gameloft fix. This fixes Gameloft games from crashing to the desktop.
Many of them do not run and crash to the desktop. This is due to a license check based on the device.
Special thanks to Christian Troy for inventing this fix. I modded it for this ROM.
8) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
I am spoofing a Samsung device that will show almost any APP as compatible.
Your device will show up in google play as Samsung device nopt a MK908 or RKSDK! Understand this please.
I also left the original build.prop in the ROM called build.orig.
If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old
Then rename build.orig to build.prop.
Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
Reboot! You should be back to showing up as a 908.
WARNING if you do this, you need to be using the 1080 kernel or your screen will be oversized!
9) I added a reboot APP that will allow optional reboot options like reboot to bootloader (flash mode).
10) 1080P Kernel if you want it! Tronsmart released a 1080 kernel but faked it back to 720.
I have unpacked it from boot and made it a choice in this ROM package.
See instructions below for how to choose the correct boot.img and kernel.img
720P boot and kernel is the default setup in my flash tool.
11) I fixed the double Camera icon showing up in the APP drawer.
For more information ALWAYS read the README in the ROM kit!
Here are the links for MK908 1.6a ROM
ROM -> Tronsmart MK908 Finless 1.6a ROM (238 megs)
Enjoy,
