MK908 Finless ROM 1.6a
hello im new here and i have to say what an amazing rom for my v3, im using it with an iphone charger and have not had 1 single rebootwell done as ive spent 4 months trying and testing loads of roms and now i will be sticking with this one.
xbmc works amazing with even 3d movies 1080 playing with no stutter (modded xbmc version with mxplayer pro and wondershare player and modded playercorefactory.xml)
just 1 question is it possible you could make an unrooted version to see if sky go will work on it? i have it installed now but only sky news will work as other channels say it will not work on rooted devices, anyway thanks again you have made me very happy.
THANKS AGAIN!!
external wifi
Great job! For the first time it feels like this little machine could see some actual use. The great improvements you've made software-wise has made the limitations of the hardware more apparent though.
Even when the wifi is working to its full potential (I'm assuming 65Mbps is the max speed), it's too slow for streaming HD material in my experience, even when streaming using nfs or dlna.
So my question is: is possible to use an external usb wifi dongle instead of the internal wifi chipset? I've seen some guides concerning the 3066 devices, and I even tried to follow them with no luck, but nothing about using an usb wifi adapter with the mk908 device.
Is it possible, using this firmware?
The wifi adapter I tried to use uses a Atheros AR9170 chipset but when I tried to insmod the module I found in a thread for 3066 devices I just got an error message.
Originally posted by ThEdOvEz View Postjust 1 question is it possible you could make an unrooted version to see if sky go will work on it? i have it installed now but only sky news will work as other channels say it will not work on rooted devices, anyway thanks again you have made me very happy.
THANKS AGAIN!!
Hello,
thx for the best rom i have ever installed on my mk908 but i have one problem, maybe someone can give me help.
The app "Sixaxis Controller" does not work correct, when i make a own touch profile (for example for Asphalt 6) it do not work, i only see a little hand when i press the button of the cotroller on my tv but there is no action for example that the car turns left or right
i never had this problem (i have installed several other roms with wifi issues and so on), it is the first time, maybe is it a issue of the rom or have i done a mistake?!
thx for help.
Great ROM finlesss I really like it although I still have wifi drop outs and reboots,
Also to note my wifi signal is great when it is working but it just reboots and after the reboot wifi is disbaled
sometimes when using it wifi just becomes diconnected which is the same as most the other roms I have tried/used, will revert back to the stock 0802 firmware as this seems to be the most stable for me but the video in the ROM is very poor.
I either have faulty hardware or non standard components I have came to the conclusion
There are currently 2516 users online. 0 members and 2516 guests.
