Heres mine: http://www.amazon.co.uk/gp/product/B...?ie=UTF8&psc=1
MK908 Finless ROM 1.6a
I resolve wifi drops & low speed with :
*a 50 cm cable for mouse wifi dongle, this devices are very sensible to interference (2,4 khz both) or I use a wired mouse
*3A PSU
*this rom
now i'm happyDevice:Tronsmart MK908 v1,Cozyswan S400
Rom: Finless Bob v1.6,Stock Rom
Kernel:Finless Bob v1.6
CWM-Recovery:by Leolas
Dear Bob,
Thank you. I had a MK908 v3 and flashed it with your finless rom 1.6 (720p) and I must say I am impressed. This is my first post and I love it.
Stock rom never allowed me to install many apps. This is super. Fast. Install Real Racing 3 as we speak.
I have one question. Can I use same rom (finless) for another stick of mine that looks like the CX-919 II with dual external antennas. (white with green color antennas? also called J22 and a variety of names)
AW: NEW - MK908 Finless ROM 1.6
_________________________
tapatalked from GalaxyS3
Excellent rom, fixed my flickerimg screen on stock. Only trouble i have is that i can't add widgets to the home screen usimg go launcher. I'm unsure if this is rom or launcher related as i can add widgets using all my other devices running go launcher. So if anybody knows a fix please let me know.
Originally posted by stevvieb View PostExcellent rom, fixed my flickerimg screen on stock. Only trouble i have is that i can't add widgets to the home screen usimg go launcher. I'm unsure if this is rom or launcher related as i can add widgets using all my other devices running go launcher. So if anybody knows a fix please let me know.
Originally posted by FadeFx View PostTry using apex launcher, it works well for me
Gamepad
This rom is excellent. Wifi works great for me. I only have one problem with gamepad. I use a ps2 controller with an usb adapter. The gamepad is recognized but right analog is inverted. I tried with tincore key mapper, inverting axes on options with no luck. Anyone knows how can i fix it? Maybe editing the pad module or something but i really don´t know how. I´ll apreciate some help. Thanks.
Originally posted by stevvieb View PostThanks for that Apex Launchers widget feature does work on the MK908 but it seems to be fairly feature lacking against Go launcher, lets hope go team fix this issue quickly like they always seem to. I was just wondering if anybody else has tried go launcher and found they can't add widgets ?
this rock is excellent. the only problem that I am having is that it does not work with the 10/100 usb Ethernet adapter that I ordered from geekbuying (High Speed USB 2.0 to RJ45 LAN Ethernet Network Adapter for MINI PC TV Box Mac Tablet ) @ http://geekbuying.com/item/High-Spee...et-314264.html
Does anyone know how to get it working? was using it on a usb hub without issue with the stock rom.
Originally posted by FadeFx View PostSure if you are into fancy eyecan(cer)dy apex is definitely not for you.
There are currently 4127 users online. 0 members and 4127 guests.
