https://www.youtube.com/watch?v=hon8...ature=youtu.be
Dr.Chads Mecool KM3 port to the Mecool KM9
Dr. Magendanz did it again, saved my Mecool KM9. I received my KM9 about 4 months ago, but it would NOT play Emby OR Plex clients, so it was useless for me. Yesterday, Dr. Magendanz, received his Mecool KM3 (essentially the same as the KM), and extracted the Android TV PIE OS, and created an image file for it. This file gave a whole new life to my KM9. These Mecool Amlogic are very easy to swap firmwares. Here is a video comparing it's capabilities to the Nvidia Shield.
https://www.youtube.com/watch?v=hon8...ature=youtu.beLast edited by trebor; 28 April 2019, 22:39.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68Tags: None
Guest
(Just for the record, I'm not a doctor....nor have I ever played one on TV. I've been a Lt. Magendanz and Rep. Magendanz, but Dr. Magendanz is my father.)
The Mecool firmware is generally pretty interchangeable as long as they're based on the same Amlogic reference boards...and these two are. While they technically report the KM9 and KM3 as u211 and u212, respectively, I haven't seen any substantive difference. The Android Pie version, however, does seem to have enabled Android Verified Boot (AVB 2.0), so don't be trying to install TWRP on it just yet.
#4.1Guest commented28 April 2019, 06:49Editing a commentJust google instructions for installing OEM firmware updates (.img files) using Amlogic's USB Burning Tool. There's nothing special that you need to do, since the boards are so similar. However, the S905X2 is notoriously sensitive to noise on the USB cable, so get a good one (braided with ferrite core) and connect to USB 2.0 port (not USB 3.0).
Originally posted by Javiersba1 View Postplease could you indicate me what are the steps to install the km3 mecool firmware in km9 please
https://www.gearbest.com/cables-conn...ml?wid=1433363
Maybe this video will help.
Originally posted by kolinsb View PostThanks for shared those info. Is there google voice remote support? Is HDMI CEC working correctly? I can use it instead of voice RC.
Sent from my POCOPHONE F1 using TapatalkMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Hi, i flashed this but cant get past the Remote control screen, my KM9 came with the basic none voice remote I tried other remotes also tried the KM8 remote which looks the same but doesnt work other then the volume and power buttons working
anyway to get past the remote control screen ?
ThanksLast edited by uscool; 29 April 2019, 11:52.
Originally posted by endera View PostKM3 to KM9 -----> Firmware Download Link???
Diese Website steht zum Verkauf! freaktab.org ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf freaktab.org alles. Wir hoffen, dass Sie hier das Gesuchte finden!
Originally posted by kolinsb View PostIs there any possibility to get OTA update? My PC can't recognize my box via USB burning tool. I tried two different PCs and two different cables, but without successMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1716 users online. 0 members and 1716 guests.
