Dr.Chads Mecool KM3 port to the Mecool KM9
Originally posted by Antoyax View PostBy the way quick question though, when your pressing the reset button inside the AV hole with a toothpick, should the device be PLUGGED IN but turned off?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Antoyax View PostI would like to clarify that while pressing the reset button, the device need not be plugged in the power supply am I right?Also thank you for your help and your videos are amazing.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Question, I installed the Stock Version of this Rom to my box, and I boot up to that blue screen telling to to pair my remote which I dont have.. is there a way to bypass it, whihch im sure there isnt at this time.. Also, I wanted to flash another ROM visa USB Burning tool, and I cant seem to get it to work since flashing this rom.. Its like Recovery mode has been disabled or something.
I press the button in AV hole while plugging in USB cord and I do have a MALE 2 MALE USB cord.. and nothing.. it wont pick it up at all..
Used to work great till I flashed stock KM3 Android TV 9 on it.. Now cant get anything to work.. cant even get into stock recovery nor use the sdcard method, Nothing at all works.
but the device still boots up.. and gets to that screen scanning for remote.. which again.. I dont have........I only have a USB Air Remote with voice control and all..
any idea on how I can get out of this predicament I got my self in? I am almost thinking I will have to buy another box.............
Originally posted by Eliminater74 View PostQuestion, I installed the Stock Version of this Rom to my box, and I boot up to that blue screen telling to to pair my remote which I dont have.. is there a way to bypass it, whihch im sure there isnt at this time.. Also, I wanted to flash another ROM visa USB Burning tool, and I cant seem to get it to work since flashing this rom.. Its like Recovery mode has been disabled or something.
I tried this ROM on my KM9. It runs fine. But there is some little problems.
Copying and pasting texts is not working with some apps. And when an external keyboard connected the virtual keyboard dissappears.
The wifi speed at 2.4GHz is stiil bad. I think that's a hardware issue.
Anyone knows any solutions about that problems?
Originally posted by srvngrc View PostI tried this ROM on my KM9. It runs fine. But there is some little problems.
There are currently 1952 users online. 1 members and 1951 guests.
