Dr.Chads Mecool KM3 port to the Mecool KM9
Originally posted by uscool View PostMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Hideiyoshi View PostSo would it be safe to say just buy the KM3 if budget permits?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Your KM8 remote should work. Turn on your cellular Bluetooth setting just to verify that your KM9 has the Bluetooth enabled.
one
Hi, I cant get into the box , after flashing this ROM with USB Burning ROM the first screen is to sync remote which i cannot do so cant go any further it came with the basic remote not the voice, when I try to use the KM8 remote it doesnt do anything when pressing the buttons following instructions , other then volume / power buttons work
one
Perhaps, Magendanz can create one. Are you sure you are using the USB 2 port on your box and NOT the USB 3 port?? Also, I always use a powered USB HUB to connect my box to. Try plugging in the power to your box first, then depress the reset button inside the A/V hole and hold it for about 10 seconds as you plug in your male to male USB cable into the black USB port on your box. Listen for the beep from your computer if your box connects to your computer.
Thx for reply. I tried that already, but it doesent help
I made boot card with Burn card maker, but I can't install this fw (installation start and just stop and back me in recovery menu). Do I need to check Yes "Erase bootloader" in this case?Last edited by kolinsb; 29 April 2019, 15:56.
I made boot card with Burn card maker, but I can't install this fw (installation start and just stop and back me in recovery menu). Do I need to check Yes "Erase bootloader" in this case?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I guess I misspoke, I thought all the KM8 boxes had the Bluetooth Voice remote. That IR remote, as you know, will not work. You can try to get it to work, by using the Android app on your cellular phone, IF you have an Android phone. I have not tried it, but others have said it works to get past that setup screen.
Thanks tried Andriod Remote app it pairs with box but pressing OK and Volume down doesnt do anything although volume up and down works and power button works same issue when use KM8 remoteMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Time to purchase a remote that will work with your device running an ATV version of Android..........
Edit: I just did a reset and came to the Bluetooth pairing screen, and YOU are correct, the app on my cell phone did NOT work. I tested a remote with a RF dongle, and it did NOT work either. So, apparently, you have to use a Bluetooth remote.
Edit 2: This remote ** should ** work..... >> https://www.aliexpress.com/item/LEOR...3bc44c4dlpWz5iMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Guest
On my custom ROMs I bypass this screen so that users with the old IR remote aren't blocked. I might be able to do that here, but right now I can only make changes to the system partition because the boot, recovery and vendor partitions are protected by Android Verified Boot. Until we figure out what key they're using for that, I'm locked out of those partitions.Last edited by Guest; 30 April 2019, 00:36.
I will do a reset on my box and see how I can get out of that screen without using my included Bluetooth remote.
https://www.aliexpress.com/item/Remo...AbTest=ae803_3
Originally posted by Magendanz View PostOn my custom ROMs I bypass screen so that users with the old IR remote aren't blocked. I might be able to do that here, but right now I can only make changes to the system partition because the boot, recovery and vendor partitions are protected by Android Verified Boot. Until we figure out what key they're using for that, I'm locked out of those partitions.
Hi, thanks for checking yeah it still might not work doesnt say its for KM9 , because the KM8 remote looks exactly the same and doesnt work this one says its for KM9
There are currently 3360 users online. 1 members and 3359 guests.
