Dr.Chads Mecool KM3 port to the Mecool KM9
Originally posted by Javiersba1 View Posthttps://youtu.be/8esZpLrJwI8 Could it also work on the Mecool km9?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Javiersba1 View PostI tried but without results nose if I will be doing something wrongMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I am sorry, it WON'T work on the KM9, only the KM9 pro or KM3...........
are you sure about that? I have flashed this image successfully to km9 the only problem is I stuck actually at initial setup as my version leaks on voice control. I ordered a Bluetooth version on Bangood still waiting it arrives. Beside that box booted fine. I will write after ir controller arrives if I'm able to finish the setup as do an initial tests with basic apps like YouTube etc.
Regards
Fossy
edit: well you were right even with Bluetooth remote is not pairing in the initial setup screen unfortinatelyLast edited by Fosphatic; 11 June 2019, 16:20.
Originally posted by Antoyax View PostThanks for the prompt reply. What shouldn't I do to not mess up my Widevine L1?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Thank you once again. I'm trying to flash my KM3 with the stock rom that I found here because I have a situation where my Netflix (hack/workaround) doesn't work unlike some of the people here in this forum where they can enjoy netflix up to 4K. Just like your youtube video where Emby worked when you changed firmware. I wonder if Magendanz' KM3 Netflix hack worked for him since the firmware is from his box.
There are currently 2128 users online. 1 members and 2127 guests.
