Dr.Chads Mecool KM3 port to the Mecool KM9
clarkss12 how are you? I haven't been following the forum in a while. My KM9 still keeps the original firmware (Android TV Oreo 8.1), since arriving here at the end of 2018 has not had any OTA updates. The annoying point I see in it is not being able to use the Netflix app for SmartTV (Netflix HD), I use the mobile version but it's not so visually cool. Will this KM3 firmware make my device have Netflix HD (L1 Permission)?
Originally posted by Novato View Postclarkss12 how are you? I haven't been following the forum in a while. My KM9 still keeps the original firmware (Android TV Oreo 8.1), since arriving here at the end of 2018 has not had any OTA updates. The annoying point I see in it is not being able to use the Netflix app for SmartTV (Netflix HD), I use the mobile version but it's not so visually cool. Will this KM3 firmware make my device have Netflix HD (L1 Permission)?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Not sure if this is the correct place for this , but I’m sure someone can fix it for me.
i wanted to share this - someone may want a rooted meoool km3 box
I would like to share this .( and it works) Get a working “ rooted” Mecool km3 – or Mecool km9 tv box Working MECOOL km9 ( rooted) ROM- I have this on my MECOOL km3 https://drive.google.com/file/d/1xqdB-gaPX8yRmAG7gZHbrMft5-Emdx-L/view?usp=drivesdk This is the TWRP for the above ROM https://drive.google.com/file/d/18OMZ2hmXNjEuziLkzfgebQFTekm_M_eb/view?usp=drivesdk And here is the directions to use TWRP to install Magisk https://android.gadgethacks.com/how-to/magisk-101-install-magisk-root-with-twrp-0179668/ Obviously you need the Amlogic USB Burning Tool 2.17 – get that and directions from the link below https://androidpctv.com/amlogic-usb-burning-tool-v2170/ Male to Male USB cable To explain a little- the Mecool ROM above is ( half rooted) if that is possible. What I mean is some root checker apps say “ yes” it’s rooted, and some say “ no”.—- But with this ROM you CAN download the above TWRP – and it works. —— Then you can use the TWRP to “ flash” Magisk, and now for sure you have a rooted Mecool km3 ( I’m guessing it will work on a MECOOL km9 box as well)
Try renaming the bluetooth name of your phone to RemoterATV3 and connect to the set-top box from your phone via bluetooth.
The prefix will see the RemoterATV3 device and the configuration will go further. Android TV Remote control needs to be installed, you can configure it through a regular IR remote.
Originally posted by Guest View PostOn my custom ROMs I bypass this screen so that users with the old IR remote aren't blocked. I might be able to do that here, but right now I can only make changes to the system partition because the boot, recovery and vendor partitions are protected by Android Verified Boot. Until we figure out what key they're using for that, I'm locked out of those partitions.
There are currently 4571 users online. 0 members and 4571 guests.
